2 Replies Latest reply on Jun 4, 2010 7:49 AM by BPM Developer
    Need to Change data in PDF form field with importData operation
    BPM Developer Level 1
      This should be simple, right?
      I have a PDF form that is submitted.  At a certain step in the process, I need to modify the value of one field from within the process.  I am using a PDF document in the default formData document variable.  To do this, I am using the exportData operation from the FormDataIntegration service to get XML.  I then use the setValue service to modify one node of the XML.  Finally, I use the importData operation from the FormDataIntegration service to import the modified data back into the PDF.
      Problem is that I am getting an error.  It says: ALC-FDI-001-304: Only XDP data is supported with XFA forms.
      Any advice?  Jasmin, Jayan, Paul, anyone?
