1 Reply Latest reply on Jun 4, 2010 2:47 AM by Moustik1664
    ItemRenderers bug while scrolling a DataGrid
    Moustik1664 Level 1
      I know this is not a new problem for Flex users, but i can't solve it.
      I'm trying to build a DataGrid with Panels as ItemRenderers. This ItemRenderer is the same for all columns, so that i can get a grid. In order to do that, my ItemRenderer implements the IDropInListItemRenderer. Each cell is a Panel, which include a label, and a List, with a color depending of the data.
      Everything work fine, and it's pretty fast.
      My problem is, when i scroll the DataGrid, all my cells are mixed up, and don't display the right data. However, with some traces, i'm sure that the datas displayed in the itemRenderer are good.
      After some search, i know that the ItemRenderers are reused by Flex, and there are some similar problems along the web. But i don't know what to do... :/
      Here is my code :
      <mx:Panel
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="100%" height="100%" implements="mx.controls.listClasses.IDropInListItemRenderer"
      horizontalScrollPolicy="
      off" verticalScrollPolicy="off" styleName="{_style}">
      <mx:Script>
      <![CDATA[
      import com.tbsfrance.project.trafficgrille.data.Donnee;
      import com.tbsfrance.project.trafficgrille.data.Stock;
      import flash.utils.setTimeout;
      import mx.binding.utils.BindingUtils;
      import mx.collections.ArrayCollection;
      import mx.controls.dataGridClasses.DataGridListData;
      import mx.controls.listClasses.BaseListData;
      import mx.controls.listClasses.IDropInListItemRenderer;
      import mx.events.ScrollEvent;
      private var _listData:BaseListData;
      Bindable]
      private var _libelle : String ;
      Bindable]
      private var _style : String = "grillePanelVide" ;
      //Define getter for the listData property
      public function get listData() : BaseListData
      return _listData ;
      //Define setter for the listData property
      public function set listData( value:BaseListData ) : void
      _listData = value;
      override
      public function set data(value:Object):void
      if(value != null) {
      super.data = value ;
      getLibelle() ;
      else
      vbox.visible =
      false ;
      this.styleName = "grillePanelVide" ;
      public
      //This is my function to analysing the data and setting the right text and style
      function getLibelle () : String
      var indice : int = int(DataGridListData(listData).dataField) ;
      if ( data is Donnee && indice >= 0)
      var mesStocks : ArrayCollection = Donnee(data).parutions[indice] ;
      if ( mesStocks && mesStocks.length > 0 )
      var stock : Stock = mesStocks.getItemAt(0) as Stock ;
      if ( stock )
      trace ("Pour " + Donnee(data).libelle + " : " + stock.emplacementLibelle + " " + stock.libelleDateParution) ;
      _libelle = stock.libelleDateParution +
      " - " + Donnee(data).libelle ;
      _style = stock.style ;
      else
      _libelle =
      _style =
      "grillePanelVide" ;
      return "" ;
      </mx:Script>
      <mx:VBox id="vbox" width="100%" height="100%" horizontalScrollPolicy="off" verticalScrollPolicy="off">
      <mx:Label id="labelCellule" styleName="grilleLabel" text="{_libelle}"/>
      </mx:VBox>
      </mx:Panel>
      Thx for your help !
