4 Replies Latest reply on Jun 6, 2010 4:07 AM by Scott R. Hamilton
    Event handler function triggered multiple times
    Scott R. Hamilton
      I've writeen an even handler for the itemFocusOut of a datagrid.
      The event handler fires multiple times each time a cell in the
      grid is tabbed out of.
      Could this be because the event handler changes the contents of
      the row in which the itemFocusOut was triggered?
      What must I do to prevent this from happening? Must the event
      handler de-register itself at the beginning and the re-register
      itself as the last statment before returning?
      Below is the trace output of the event handler function eventually a run time
      error is provoked.
      disableEditMode(): Entry Point - event type: itemFocusOut   target control: EditRecipe2_515.Canvas517.dgRecIngr
      Converting: 1/8
      Converting: 1/8
      ParseAndConvertFraction returns: 0.125
      Converting: 1/8
      Converting: 1/8
      Converting: 1/8
      Converting: 1/8
      Converting: 1/8
      Converting: 1/8
      undefined
          at ModuleManagerImpl/getAssociatedFactory()[C:\autobuild\3.5.0\frameworks\projects\framework \src\mx\modules\ModuleManager.as:150]
          at mx.modules::ModuleManager$/getAssociatedFactory()[C:\autobuild\3.5.0\frameworks\projects\ framework\src\mx\modules\ModuleManager.as:64]
          at mx.core::UIComponent/getClassStyleDeclarations()[C:\autobuild\3.5.0\frameworks\projects\f ramework\src\mx\core\UIComponent.as:7682]
          at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::initThemeColor()[C:\autobuild\3.5.0\frameworks \projects\framework\src\mx\core\UIComponent.as:8025]
          at mx.core::UIComponent/styleChanged()[C:\autobuild\3.5.0\frameworks\projects\framework\src\ mx\core\UIComponent.as:5661]
          at mx.controls::Button/styleChanged()[C:\autobuild\3.5.0\frameworks\projects\framework\src\m x\controls\Button.as:1632]
          at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::addingChild()[C:\autobuild\3.5.0\frameworks\pr ojects\framework\src\mx\core\UIComponent.as:5255]
          at mx.core::UIComponent/addChild()[C:\autobuild\3.5.0\frameworks\projects\framework\src\mx\c ore\UIComponent.as:4966]
          at mx.controls.alertClasses::AlertForm/createButton()[C:\autobuild\3.5.0\frameworks\projects \framework\src\mx\controls\alertClasses\AlertForm.as:472]
          at mx.controls.alertClasses::AlertForm/createChildren()[C:\autobuild\3.5.0\frameworks\projec ts\framework\src\mx\controls\alertClasses\AlertForm.as:176]
          at mx.core::UIComponent/initialize()[C:\autobuild\3.5.0\frameworks\projects\framework\src\mx \core\UIComponent.as:5381]
          at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()[C:\autobuild\3.5.0\frameworks\pro jects\framework\src\mx\core\UIComponent.as:5278]
          at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::childAdded()[C:\autobuild\3.5.0\frameworks\pro jects\framework\src\mx\core\Container.as:3348]
          at mx.core::Container/addChildAt()[C:\autobuild\3.5.0\frameworks\projects\framework\src\mx\c ore\Container.as:2260]
          at mx.core::Container/addChild()[C:\autobuild\3.5.0\frameworks\projects\framework\src\mx\cor e\Container.as:2183]
          at mx.controls::Alert/createChildren()[C:\autobuild\3.5.0\frameworks\projects\framework\src\ mx\controls\Alert.as:713]
          at mx.core::Container/initialize()[C:\autobuild\3.5.0\frameworks\projects\framework\src\mx\c ore\Container.as:2569]
          at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::childAdded()[C:\autobuild\3.5.0\frameworks\pro jects\framework\src\mx\managers\SystemManager.as:2131]
          at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::rawChildren_addChildAt()[C:\autobuild\3.5.0\fr ameworks\projects\framework\src\mx\managers\SystemManager.as:2181]
          at mx.managers::SystemManager/addChildAt()[C:\autobuild\3.5.0\frameworks\projects\framework\ src\mx\managers\SystemManager.as:1702]
          at mx.managers::SystemManager/addChild()[C:\autobuild\3.5.0\frameworks\projects\framework\sr c\mx\managers\SystemManager.as:1685]
          at mx.managers::PopUpManagerImpl/addPopUp()[C:\autobuild\3.5.0\frameworks\projects\framework \src\mx\managers\PopUpManagerImpl.as:309]
          at mx.managers::PopUpManager$/addPopUp()[C:\autobuild\3.5.0\frameworks\projects\framework\sr c\mx\managers\PopUpManager.as:169]
          at mx.controls::Alert$/show()[C:\autobuild\3.5.0\frameworks\projects\framework\src\mx\contro ls\Alert.as:519]
          at EditRecipe2/ParseAndConvertFraction()[C:\Users\Scott\Documents\Flex Builder 3\Culinaria\src\EditRecipe2.mxml:338]
          at EditRecipe2/disableEditMode()[C:\Users\Scott\Documents\Flex Builder 3\Culinaria\src\EditRecipe2.mxml:298]
          at EditRecipe2/__dgRecIngr_itemFocusOut()[C:\Users\Scott\Documents\Flex Builder 3\Culinaria\src\EditRecipe2.mxml:547]
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.core::UIComponent/dispatchEvent()[C:\autobuild\3.5.0\frameworks\projects\framework\src \mx\core\UIComponent.as:9440]
          at mx.controls::DataGrid/destroyItemEditor()[C:\autobuild\3.5.0\frameworks\projects\framewor k\src\mx\controls\DataGrid.as:4024]
          at mx.controls::DataGrid/itemEditorItemEditEndHandler()[C:\autobuild\3.5.0\frameworks\projec ts\framework\src\mx\controls\DataGrid.as:4934]
          at mx.controls::DataGrid/endEdit()[C:\autobuild\3.5.0\frameworks\projects\framework\src\mx\c ontrols\DataGrid.as:4085]
          at mx.controls::DataGrid/collectionChangeHandler()[C:\autobuild\3.5.0\frameworks\projects\fr amework\src\mx\controls\DataGrid.as:4282]
          at mx.collections::ListCollectionView/dispatchEvent()[C:\autobuild\3.5.0\frameworks\projects \framework\src\mx\collections\ListCollectionView.as:879]
          at mx.collections::ListCollectionView/replaceItemsInView()[C:\autobuild\3.5.0\frameworks\pro jects\framework\src\mx\collections\ListCollectionView.as:1510]
          at mx.collections::ListCollectionView/listChangeHandler()[C:\autobuild\3.5.0\frameworks\proj ects\framework\src\mx\collections\ListCollectionView.as:1116]
          at mx.collections::ArrayList/setItemAt()[C:\autobuild\3.5.0\frameworks\projects\framework\sr c\mx\collections\ArrayList.as:267]
          at mx.collections::ListCollectionView/setItemAt()[C:\autobuild\3.5.0\frameworks\projects\fra mework\src\mx\collections\ListCollectionView.as:462]
          at EditRecipe2/disableEditMode()[C:\Users\Scott\Documents\Flex Builder 3\Culinaria\src\EditRecipe2.mxml:316]
        • 1. Re: Event handler function triggered multiple times
          Flex harUI Adobe Employee
          Set a breakpoint and examine the callstack.  It might give you a clue as to
          how to prevent a callback.  You can always set a flag to ignore other calls.
          • 2. Re: Event handler function triggered multiple times
            Scott R. Hamilton Level 1
            Hi Alex,
            Thanks for your reply.
            I am not sure how to implement your suggestion of using a flag to
            prevent callbacks from occurring.
            Presumably the flag variable would be defined globally within the
            component so that it would be visible from within the event handler
            function.
            How and when would this flag be set and unset and how would this
            prevent the callback from occurring?
            Scott
            • 3. Re: Event handler function triggered multiple times
              Class Foo
                  private var inMyHandler:Boolean;
                  private function myHandler(event:Event):void
                      if (inMyHandler) return;
                      inMyHandler = true;
                      // do whatever
                      inMyHandler = false;
              • 4. Re: Event handler function triggered multiple times
                Hi Alex,
                I tired this and now I'm getting a runtime error. The trace ouptput is below
                The first two lines of output is the function printing its signature and state.
                As soon as the function starts to do some work the error occurs.
                After I stop execution in the debugger I can see that the function has run
                correctly and I can make another change in the datagrid and the function will be
                called again and run without error.
                Scott
                disableEditMode(): Entry Point - selectedIndex: 1    selectedItem: [object Object]
                disableEditMode(): Entry Point - bFuncBlock = TRUE
                TypeError: Error #1009: Der Zugriff auf eine Eigenschaft oder eine Methode eines null-Objektverweises ist nicht möglich.
                    at mx.controls::DataGrid/destroyItemEditor()[C:\autobuild\3.5.0\frameworks\projects\framewor k\src\mx\controls\DataGrid.as:4026]
                    at mx.controls::DataGrid/findNextItemRenderer()[C:\autobuild\3.5.0\frameworks\projects\frame work\src\mx\controls\DataGrid.as:3990]
                    at mx.controls::DataGrid/keyFocusChangeHandler()[C:\autobuild\3.5.0\frameworks\projects\fram ework\src\mx\controls\DataGrid.as:4747]
