2 Replies Latest reply on Jun 9, 2010 11:00 PM by nishadmusthafa
    How to embed interaction in flex video player..
    magzkd
      Hi All,
      I have scenario in which I need to bring interaction(like doing survey or askig username and pwd) in flex video player while playing the video.Do flex video player have any events for this...i'm using flex 4...Can anyone help me on this??
      thanks
      magz
        • 1. Re: How to embed interaction in flex video player..
          Unni Gopinathan S Adobe Employee
          VideoDisplay have an event called "enterFrame" which will get triggered for every frame.
          Another way is to set "cuePoints" and "cuePoint event".
          Flex examples for cue points.
          http://blog.flexexamples.com/2007/08/09/dynamically-creating-actionscript-cue-points-from- flashvars-received-from-the-html-container/
          http://blog.flexexamples.com/2007/07/29/creating-actionscript-cue-points-with-the-videodis play-control/
          Sample code which will popup the login form in the begining of the video and after playing half video.
          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                  xmlns:mx="library://ns.adobe.com/flex/mx" width="820" height="519">
          <fx:Script>
            <![CDATA[
             private var frameCount:int=0;
             private var notreachedMid:Boolean = true;
             protected function myVid_enterFrameHandler(event:Event):void
              if(myVid.playheadTime == 0 && frameCount == 0)
               trace("Login in start up.");
               this.currentState="loginState";
               frameCount++;
              else if(myVid.playheadTime > (myVid.totalTime/2) &&  notreachedMid)
               trace("Login after playing half");
               myVid.pause();
               notreachedMid = false
             protected function button1_clickHandler(event:MouseEvent):void
              if(usrName.text == "unni" && passWrd.text == "unni")
               callLater(foo);
               usrName.text ="";
               passWrd.text="";
               myVid.play();
             private function foo():void
              this.currentState="StartState";
          </fx:Script>
          <s:states>
            <s:State name="StartState">
            </s:State>
            <s:State name="loginState">
            </s:State>
          </s:states>
          <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <mx:VideoDisplay id="myVid" source="E:\FlashBuilderWrkSpaces\Project\TestProject\assets\20051210-w50s.flv" autoPlay="false"
                x="10" y="10" width="800" height="500" enterFrame="myVid_enterFrameHandler(event)" />
          <mx:Form includeIn="loginState" x="273" y="206">
            <mx:FormItem label="Name">
             <mx:TextInput id="usrName"/>
            </mx:FormItem>
            <mx:FormItem label="Password">
             <mx:TextInput id="passWrd" displayAsPassword="true"/>
            </mx:FormItem>
            <mx:FormItem >
             <mx:Button label="Submit" click="button1_clickHandler(event)"/>
            </mx:FormItem>
          </mx:Form>
          </s:WindowedApplication>
          • 2. Re: How to embed interaction in flex video player..
            nishadmusthafa
            You could create a small custom component(something like a form). Create a custom skin for your video player which is a copy of
            spark.skins.spark.VideoPlayerSkin
            You can then add the component you created for the interactions to this skin. Go through the source code of the skin to get a better idea of what i want.
            This is just one solutions. there are other ways. Do let me know if you require anything specific.
            Nishad
