5 Replies Latest reply on Jun 18, 2010 12:52 PM by John Hall
    Basic SWFLoader question
    John Hall Level 4
      Reducing my code down to a simply clip, I have something along the lines of the following:
      import mx.managers.SystemManager;
      public var container1:SystemManager;
      private function initPic1():void{
          container1 = SystemManager(pic1.content);
      <mx:SWFLoader includeIn="mainDisplay"
      id="pic1"
      source="assets/images/spaces/outsideToLobby.swf"
      complete="initPic1()"/>
      As soon as initPic1 is invoked, I get a coercion failure message : Type Coercion failed: cannot convert outsideToLobby_fla::MainTimeline@51a8f061 to mx.managers.SystemManager.
      Why fla type? More importantly, do you see a syntax problem that would cause the issue?
        • 1. Re: Basic SWFLoader question
          Flex harUI Adobe Employee
          Most SWFs built from a FLA do not have a SystemManager as the root.
          • 2. Re: Basic SWFLoader question
            BhaskerChari Level 4
            Hi John Hall,
            The "pic1.content" will get you a reference to the Flash SWF MainTimeline but not the SystemManager(By assuming the SWF loaded is a Flash SWF).
            You can try out the below code without Casting the content:
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init()">
                <mx:Script>
                 <![CDATA[
                  import mx.utils.StringUtil;
                  import mx.controls.Text;
                  import flash.net.navigateToURL;
                import flash.net.LocalConnection;
                 import mx.controls.Alert;
                 private var conn:LocalConnection;
                 private var loadedSWFMainTimeline:*;
                    public function onSWFLoadComplete():void {
                Alert.show("onSWFLoadComplete");
                         //loadedSWFMainTimeline gets you a reference to the Flash SWF MainTimeline
                loadedSWFMainTimeline = swfLoader.content;
                if(loadedSWFMainTimeline)
                var _button:SimpleButton = loadedSWFMainTimeline.flash_button as SimpleButton;
                _button.addEventListener(MouseEvent.CLICK,onMCButtonClick);
                public function onMCButtonClick(event:MouseEvent):void {
                Alert.show("Flash Button Clicked");
                </mx:Script>
                <mx:VBox>
                 <mx:SWFLoader id="swfLoader" source="assets/lifeinsurance.swf" complete="onSWFLoadComplete();"/>
                 <mx:TextArea id="output" width="221" height="221" wordWrap="true"/>
                </mx:VBox>
            </mx:Application>
            Note: In the above code flash_button is the button instance of the Flash SWF.
            If this post answers your question or helps, please kindly mark it as such.
            Bhasker Chari
            • 3. Re: Basic SWFLoader question
              John Hall Level 4
              I must be so overlooking something basic. What I've gone to is a swfloader. If I hard-wire the source in the mxml, all works fine. If I use actionscript (reduced to bare minimum) in the same component, I can not get the swf to load.
              In short, the SWFLoader name is "myMovie" (as of this hour ;-)
              If I debug, the source is there as a String, which seems legal since it's typed as an Object including string or MC or whatever. However, the content of the SWFLoader remains null. The complete event (hard-wired in the mxml component or using ActionScript with an eventListener) never fires.
              I've tried setting the source with movieSource bindable. In the component it reads
              <mx:SWFLoader id="myMovie"
                                autoLoad="true"
                                source = "{movieSource}"
                                toolTip="Click on front entrance to navigate there."
                                width="986"
                                height="576"
                                verticalCenter="-1"
                                horizontalCenter="0"
                                complete="initMovie()"
                                click="trace('myMovie here');startCutAnimation()"/>
              initMovie never fires.
              I've tried actionscript with
              and the actionscript snipped that is invoked is:
              movieSource  = "resources/assets/" + movie + ".swf"; (yes it exists and is spelled correctly as it works when hard-wired)
              myMovie.source = movieSource;
              complete event never fires
              I've tried myMovie.load(movieSource) and myMovie.load("resources/assets/outsideToLobby.swf";
              The source is always correct when I debug but no content.
              I've tried invalidating properties, invalidating displaylists, invalidating my attitude and non of those have an effect. I must be missing a typo or a simple principle. Thanks for any help.
              • 4. Re: Basic SWFLoader question
                Hi John Hall,
                Try to give the path ...correctly, if you assign the source correctly to the SwfLoader then the complete event should defenitely get called...
                what value is there in "movie" variable in above line of code....
                Once try giving the source directly wothout using the varible....However it makes no difference but I suspect that movie variable is not being populated correctly..
                Bhasker Chari
                • 5. Re: Basic SWFLoader question
                  John Hall Level 4
                  Thanks for taking the time to try to answer. I found the issue was unrelated to the component. I'm using the Mate Framework and I was dispatching events to a new instance of the class each time instead of the instance that was already created. Somedays, I can spend 3 hours and finally find the mis-spelling but it always seems to help to voice the question because it makes me question the logic of the question.
                  Thanks again.
                  John
