4 Replies Latest reply on Jun 8, 2010 7:36 AM by haroldswift
    After Effects CS5 is crashing my Mac when I trim a clip
    haroldswift Level 1
      I don't have much to explain this further but After Effects CS5 is crashing my Mac when I trim a clip.  It completely turns off my Mac when I trim a clip. The only other similar thing is Photoshop CS5 is also doing crashing my Mac when I resize large images.  Small images are fine but large 300dpi images crashes it without warning. Don't know what to do.
      I have 8gigs of Ram and am running 27" iMac Core i5
      Any help would be much appreciated!
      Hal
        • 1. Re: After Effects CS5 is crashing my Mac when I trim a clip
          Andrew Yoole MVP & Adobe Community Professional
          If your system is physically powering off with any software interaction, you almost certainly have a hardware issue. It could be faulty RAM or a faulty video card.
          Try removing the OpenGL plugin temporarily to eliminate OpenGL as the problem.
          I'd suggest re-installing After Effects (or a full OS install if you can afford the time).  If the problem remains, I'd take it to a qualified service person.
          • 2. Re: After Effects CS5 is crashing my Mac when I trim a clip
            Wade_Zimmerman Level 6
            Are you running these two program together?
            I would think so.OK you are probably running them both as 64 bit that is great that they run 64 bit and can use more RAM and even better they actually do use more RAM.
            So the solution is probably more RAM, don't run them to together or lower the expectations of Photoshop and AE.
            That way they won't try to use all the RAM to do this work. It will probably do the wrk pretty fast but not as fast if you had more RAM maybe.
            Also AE and PS on an iMac, what about your scratch disk. Is it a very fast external drive and how is it connected?
            If you don't have a fast internal drive say with at least a 32MB buffer running at 7200rpm then there you go a real contributing ffactor.
            To be honest you need both more RAM and a fast start up disk and a fast external scratch.
            The new 2TB drives by Seagate run at 7200 rpm and have  64 MB cache which s as important as the rotation. You can possibly make a Raptor an external scratch as well at 300 GB they are probably not arge enough s a start up.
            Those are my thoughts.
            16 GB of RAM a larger faster internal drive lower the performance and memory setting as well.
            • 3. Re: After Effects CS5 is crashing my Mac when I trim a clip
              Turn off OpenGL usage. Due to the high-res display in that particular iMac model, the graphics processor is operating on the edge of its performance already without any other tool burdening it further. Using OpenGL features will only push it over the edge.
              Mylenium
              • 4. Re: After Effects CS5 is crashing my Mac when I trim a clip
                haroldswift Level 1
                Wow! Thanks guys! This was quite helpful. It would seem to me the RAM is probably the problem with Photoshop, but just realized that I was importing a CS4 After Effects project into a CS5  project using import.  So, when I would just open up the CS4 project CS5 would convert it and everything was fine.
                I will take that advice about RAM though. 8 gigs is probably on the edge. Would you say 16 gig would be better?
                Hal
