3 Replies Latest reply on Jun 6, 2010 8:58 AM by the_wine_snob
    Easiest way to remove live sound
    ruzun Level 1
      When I edit projects I rarely use the "live" sound recorded by the camcorder.  In Premiere Elements I could just select a clip in the timeline and delete the audio via right mouse click and select.  In CS5 I seem to have to unlink the clip from its audio, then select the audio portion only and delete that.
      Is there some quick way to drop a clip into the timeline without it's audio track, or is there a quicker way of deleting the audio for a clip other than unlink and clear?
      -Roger Uzun
        • 1. Re: Easiest way to remove live sound
          shooternz Level 6
          Many ways to do what you want...
          easiest for you maybe...
          Bring the clip in via the source monitor and drag video only to the timeline using Video icon only.
          Apart from that...you can un target the audio timeline and drag in the entire source frame.
          or...you could map the audio of a clip(s) to no audio.
          Then you could ALT-Click the audio part of a clip in the timeline and hit DEL
          • 2. Re: Easiest way to remove live sound
            Colin Brougham Level 6
            Craig's suggestions are probably all the best for accomplishing what you want, but I'll offer one more suggestion for the fun of it...
            Personally, I like to add both the video and audio portions of a clip into a sequence, because even though I may be pretty sure that I won't use the audio, I like having the option. Instead of fussing with turning off tracks and so on, I simply hold down the Alt key and select just the audio portion of a sequence clip (or just video, if you want the audio) and right-click and toggle the Enable option. This leaves that portion of the clip in the timeline, linked to the other portion, but effectively "mutes" it. This way, if I decide I want the audio (or video) later, I just have to reverse the process, and I don't have to turn off everything in a track by muting it, so I can be selective of the clips that pass through to output.
            Again, this is a more specialized function, but might be helpful at times.
            • 3. Re: Easiest way to remove live sound
              the_wine_snob Level 9
              I most often use Colin's method, with a tiny twist. As I use Audio Mixer so much, I just hit Mute for that Track, 'cause I'm already there, and am lazy.
              So many ways, so many ways.
