3 Replies Latest reply on Jun 7, 2010 3:23 AM by Harbs.
    While Loop with Array.pop() Gotcha
    Harbs. Level 6
      Just a bit of a heads up:
      A number of us have been using a while(obj=array.pop()){} construct for a while. (I believe Marc was the one to introduce this construct to this forum.)
      While this is considerably more efficient than a standard for loop when you don't need the array when the loop ois done, there's a not-so-obvious gotcha:
      0 in javascript is evaluated to false, so : while(0) is equivalent to while(false).
      If you have an loop like this:
      ar = [1,0,8,6];
      while(a=ar.pop()){
          // do your stuff
      6 and 8 will resolve true, but 0 will not. The loop will exit when it hits 0, and neither 0 nor 1 will be processed.
      This loop is no good either:
      ar = [1,0,8,6];
      while(a=ar.pop() != null){
          //do your stuff
      because "a" will evaluate to either true or false instead of the value of the array because statements are processed backwards (i.e. a = (ar.pop != null)).
      Instead you need (note the extra parenthesis):
      ar = [1,0,8,6];
      while((a=ar.pop()) != null){
          //do your stuff
      HTH,
      Harbs
        • 1. Re: While Loop with Array.pop() Gotcha
          Harbs. Level 6
          Actually, even the last construct is not  safe. If there's a null object in the array it'll exit prematurely as well.
          For null objects, this will work:
          ar = [1,null,8,6];
          while((a=ar.pop()) !== undefined){
              //do your stuff
          But if you have a non-consecutive array this too will fall flat on its face:
          ar = [1,null,8,6];
          ar[6] = 2;
              //this will only process 2
          Bottom line, don't use the pop() as the condition of the loop. Do something like this instead:
          ar = [1,null,8,6];
          ar[6] = 2;
          while(ar.length){
              a=ar.pop();
              // now we can process all elements of the array!
          Harbs
          • 2. Re: While Loop with Array.pop() Gotcha
            Marc Autret Level 4
            Good point, Harbs ;-)
            That's why I wouldn't recommand using the while( a=ar.pop() ){...} pattern on simple one-dimensional arrays that contain, or could contain primitive types. As a general rule I use this tip on temporary arrays of objects, or on n-dimensional temporary arrays, because I am absolutely sure that none of the elements can be evaluated to false. Then it is a useful shortcut. In other situations the old good index loop is the best although it requires an additional variable.
            Marc
            • 3. Re: While Loop with Array.pop() Gotcha
              Harbs. Level 6
              Hi Marc,
              I wasn't blaming you for my mistakes! I just got bitten by using this technique for primitive type arrays, and I figured I should prevent others from making my mistake...
              But even for primitive arrays, while(array.length)array.pop() is more efficient than a for loop.
              Harbs
