1 Reply Latest reply on Jul 25, 2010 4:18 AM by Dirk Becker
    Unable to start cs3 server on os x 10.6.3
    mhoehn@hotmail.de
      After starting from a shell server terminates with following error:
      Sun Jun  6 12:28:11 2010 INFO    [Server] Initialisierung
      Sun Jun  6 12:28:11 2010 INFO    [Server] Anwendung wird geladen
      Sun Jun  6 12:28:11 2010 INFO    [Server] Zusatzmodule werden gesucht
      Sun Jun  6 12:28:11 2010 INFO    [Server] 105 Zusatzmodule werden registriert
      Sun Jun  6 12:28:13 2010 INFO    [Server] Objektmodell wird fertig gestellt
      Sun Jun  6 12:28:13 2010 INFO    [Server] Objektmodell wird gespeichert
      Sun Jun  6 12:28:13 2010 INFO    [Server] Zusatzmodule werden initialisiert
      Sun Jun  6 12:28:13 2010 INFO    [Server] "Early Initializers" werden aufgerufen
      Sun Jun  6 12:28:13 2010 INFO    [Server] Dienstregistrierung wird gestartet
      terminate called after throwing an instance of 'devtech::LM_exception'
        what():  Can't find user application support folder!
      ./startup_id3.sh: line 4: 68749 Abort trap              InDesignServer.app/Contents/MacOS/InDesignServer -iorfile "/ior.txt" -pluginpath "Server/Corba" -previews
      sh-3.2#
      Any idea for a solution?
        • 1. Re: Unable to start cs3 server on os x 10.6.3
          Dirk Becker Level 4
          No experiences here with that exact combination.
          Something general:
          Make sure access rights on the application support folder are correctly set for the user account that you're using to launch InDesign.
          Run the OSX repair privileges utility.
          Compare the general folder structure to your desktop installation, or the earlier installation (replacing an old hardware?).
          If that fails:
          Launch the application from within Instruments (which comes with the optional installation of developer tools, e.g. XCode)
          Trace file access and watch out for error results.
          Dirk
