1 Reply Latest reply on Aug 15, 2007 10:12 AM by Newsgroup_User
    Dynamic Click Tracking Without clickTag
    noynek
      I've got an unusual circumstance where I'm not loading my flash file from within a webpage. Normally I use getURL() with clickTag to set my destination URL and tracking URL in the html, but in this case I am setting all of my variables using SetVariable() to support Player 7.
      My question is: how can I set a button to open a destination URL and call the tracking URL dynamically using SetVariable()?
      The current logic looks like this:
      1. flash file loads
      2. Using the watch() method, the flash file populates as variables are passed in using SetVariable()
      I've figured out how to do simple things like change the text, but I'm not sure how to set a button URL and a tracking URL for when that button is clicked.
      Ideas? Thank you!
        • 1. Re: Dynamic Click Tracking Without clickTag
          Level 7
          noynek,
          The only reason for using SetVariables(), which is a JavaScript function
          specific to Flash, is in cases where you want to update a variable *after*
          the SWF has already loaded (such as, for example, to change it from a
          default value at some later time). If the variable only needs to be set
          once, when the SWF is requested by the HTML, then FlashVars or a query
          string on the SWF's file name itself is all you need.
          There are quite a few ways to define variables in a SWF (variables are
          nothing more than special containers to hold data). In a keyframe of any
          timeline, for example, you can do something like this:
          var destination:Sring = " http://www.domain.com/";
          Of course, that "bakes" the variable into the SWF itself. It is set and
          may be referenced by that SWF. If you want to set such a variable from
          *outside* the SWF, such as from the HTML document, then it can be attached
          as a querty string to the name of the SWF file itself ...
          <param name="movie" value="myMovie.swf?destination=http://www.domain.com/"
          ... or passed in via a FlashVars attribute ...
          <param name="FlashVars" value="destination=http://www.domain.com/" />
          ... or, as you've indicated, with the SetVariable() function ...
          // JavaScript
          swfFileReferenct.SetVariable("destination", " http://www.domain.com/");
          In any of the above cases, a variable named destination (just an
          arbitrary, descriptive name) is created in the main timeline (assuming the
          first example, with "var", was typed in a keyframe of the main timeline).
          At any point in the SWF, the variable destination can be referenced, and its
          value will be (in this case) http://www.domain.com/, unless it is changed to
          something else later.
          > 1. flash file loads
          Does this mean it is requested by the HTML document, or you're using a
          main SWF file to load another SWF file?
          I'm curious why you're using Object.watch(). Not saying you're
          necessarily wrong to do so, but maybe it would help to show your code?
          Your button would presumably call getURL() (or maybe a LoadVars
          instance?) in response to a mouse click. The first parameter of getURL() is
          a URL, which would be the name of whatever variable contains the value you
          want to reach.
          David Stiller
          Co-author, Foundation Flash CS3 for Designers
          http://tinyurl.com/2k29mj
          "Luck is the residue of good design."
