quote:Actually, I release both the Word and .PDF documents for the convenience of my customers.
Originally posted by: Peter Grainge
First, the users will not see the error as you will have corrected and saved it before you release the document, indeed before you PDF it and it is the PDF you will be releasing.
Your second paragraph reveals the cause of the problem, a home brewed template. Take a look at the topic on my site about Printed Documentation. There I recommend using the Style Mapping template. I have seen so many problems that go away when people stop using their own templates and using that tone. There is nothing wrong that anyone can find with the home brewed template so don't see it as meaning you have done something wrong in that template. However Style Mapping will almost certainly get it right.When I selected the Style Mapping.dot template, the generated .PDF document TOC and index listings were correct. The Word document TOC listing was correct but the index was not. But of course the heading styles were goofy.
First just generate using the supplied Style Mapping and check the page numbers to confirm they are correct. That will import the copy in Program Files into your project. Assuming it fixes the problem, amend the styles using by importing from your template. When you have got that right with the Letter size paper of that template, rename it Style Mapping US. Create a copy and name it Style Mapping A4. In that copy change the paper size to A4 and the Language to English UK.
Let me know how that goes.
