2 Replies Latest reply on Jun 6, 2010 5:23 PM by hipgrrl
    Change file name on save
    hipgrrl
      Hi all- I am new to scripting, and have come across a problem I am not able to figure out using conventional methods.
      Part of my post processing calls for the crop and straighten filter. My action runs crop & straighten, closes the original file then after a couple more steps saves the resulting cropped  image as an uncompressed tiff. The problem is when the cropped file is created, Photoshop adds " copy" to the file name.
      Is there any scripting way to remove " copy" from the file name during the save as tiff?
      Any help would be greatly appreciated.
        • 1. Re: Change file name on save
          Michael L Hale Level 5
          You should be able to change the name to anything you like including removing the word copy from the name. If you will post the save part of your script I will show you how to change it.
          • 2. Re: Change file name on save
            hipgrrl Level 1
            Thanks for the response.
            I am currently not using scripting at all in my workflow so originally the steps of my action were as follows:
            crop & straighten
            select previous document
            close current document without saving
            place gif image into image (watermark)
            flatten
            save as uncompressed tiff to c:/highres
            image size 72 DPI
            fit image 900 px 900 px
            save as jpeg to c:/lores
            close
            The workaround way I came up with to get around having copy in the  file name is to do:
            crop & straighten
            select all
            cut
            paste
            select transparency channel
            crop
            flatten
            image size 72 dpi
            close
            I would like to keep the action as it is in the first version and not have to use the workaround I came up with, so I can just add a script at the end to save the image and remove the word copy from the file name.
