2 Replies Latest reply on Jun 6, 2010 8:04 PM by Miggl
    Error #1065: Variable xxx is not defined.
    Miggl Level 1
      Hi All,
      I'm really stumped on this one. I've seen on other forums where they recommend creating a dummy instance to make sure it is compiled into the SWF, but I have that. Also, I have other classes that work just fine.
      Here's the code that is failing on the line getDefinitionByName():
      var objClass:Class = getDefinitionByName(baseDataType) as Class;
      This works with:
      package
      com.emmgee.geneomatic.valueObjects
      import com.emmgee.datomatic.models.DatOMaticObject;
      Bindable]
      Table(name="source_models")]
      public class SourceModelVO extends DatOMaticObject
      PrimaryKey]
      public var id:int;
      public var name:String;
      Column(name="sourcecategory_id")]
      public var sourcecategory:SourceCategoryVO;
      public var description:String;
      public var source_field_id:int;
      But not with:
      package
      Bindable]
      Table(name="source_records")]
      public class SourceRecordVO extends DatOMaticObject
      PrimaryKey]
      public var id:uint;
      Column(name="sourcemodel_id")]
      public var sourceModel:SourceModelVO;
      public var title:String;
      Column(name="is_direct")]
      public var isDirect:Boolean;
      Column(name="is_original")]
      public var isOriginal:Boolean;
      Column(name="is_primary")]
      public var isPrimary:Boolean;
      Column(name="is_legible")]
      public var isLegible:Boolean;
      In the first case the variable baseDataType reads "com.emmgee.geneomatic.valueObjects::SourceModelVO", and in the second case it reads "com.emmgee.geneomatic.valueObjects::SourceRecordVO".
      The error reads "Error #1065: Variable SourceRecordVO is not defined.
      at global/flash.utils::getDefinitionByName()
      at com.emmgee.datomatic.models::DatOMaticObject/parseMetaData()[C:\Users\Mike\Zend\workspace s\DefaultWorkspace7\Dat-O-Matic\src\com\emmgee\datomatic\models\DatOMaticObject.as:110]
      at com.emmgee.datomatic.models::DatOMaticObject/save()[C:\Users\Mike\Zend\workspaces\Default Workspace7\Dat-O-Matic\src\com\emmgee\datomatic\models\DatOMaticObject.as:61]
      at com.emmgee.geneomatic.modules::Sorcerer/fileSelectHandler()[C:\Users\Mike\Zend\workspaces \DefaultWorkspace7\Gene-O-Matic for the Desktop\src\com\emmgee\geneomatic\modules\Sorcerer.mxml:173]
      ", where line 110 is the getDefinitionByName line above.
      Any ideas why this is happening with one class, but not the other?
      ~Mike
      Update:
      This is the oddest thing. So I found another thread that showed how to see if the object is actually loaded in the application domain.
      I instanciated SourceRecordVO in one line (no error), and in the next line the following returned false:
      loaderInfo.applicationDomain.hasDefinition(
      "com.emmgee.geneomatic.valueObjects.SourceRecordVO");
      What gives? How can it resolve it in one line, then forget about it in the next??
        • 1. Re: Error #1065: Variable xxx is not defined.
          Miggl Level 1
          Update: I found a thread that showed how to check if the class was loaded in the application domain. So, in my code I instanciate the class on one line and manipulate it without errors, and on the next line I check if its loaded in the application domain, only to find out it isn't! What gives?
          this._sourceRecord = new SourceRecordVO();
          this._sourceRecord.save();
          • 2. Re: Error #1065: Variable xxx is not defined.
            Miggl Level 1
            One work-around is to add the following compiler parameter:
            -includes=com.emmgee.geneomatic.valueObjects.SourceRecordVO
            I'm not sure why it's not including this specific class in compiled code, while it is include other dynamic classes. I would love to figure that out in order to fix this problem. Thoughts?
