2 Replies Latest reply on Jun 6, 2010 9:27 PM by SiHoop
    Subset of an arrayCollection
    SiHoop
      How do I select a subset of an array
      Collection to appear in a datagrid? For example, in the code below, how do I select only the records where pop > 2000?
      <?xml version="1.0"?>
      <!-- dpcontrols\SimpleDP.mxml -->
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"  creationComplete="creationCompleteHandler()">
          <mx:Script>
              <![CDATA[
      import mx.collections.ArrayCollection;
      [Bindable] private var _populations:ArrayCollection;
                  public function creationCompleteHandler():void {
                      _populations=new ArrayCollection;
                      _populations.addItem({country: "Canada", continent:"NA", pop:"50"});
                      _populations.addItem({country: "Ven", continent:"SA", pop:"1000"});
                      _populations.addItem({country: "USA", continent:"NA", pop:"5000"});
                      _populations.addItem({country: "Brazil", continent:"SA", pop:"4000"});
          </mx:Script>
          <mx:DataGrid  id="datagrid"   dataProvider="{_populations}" width="100%" height="100%" />
      </mx:Application>
        • 1. Re: Subset of an arrayCollection
          David_F57 Level 5
          hi,
          You use a filter function on your array collection, this is reasonably simple I have a basic example which I did for another poster a few weeks back
          http://flashhub.net/filter/ - source is included
          So your filter would look something like this, you could hard code the value in but it is always better to use variables so that any part of your program can alter the filter requirements.
                                  private var minPopulation: int = 500;  <=== global variable
                      protected function arrColl_filterFunc(item:Object):Boolean
                              if (item.pop > minPopulation)
                                  return true
                              else
                                  return false;
          • 2. Re: Subset of an arrayCollection
            SiHoop Level 1
            Nice-- thanks.
