Employees create a pdf file from data, they complete a QA form that I've created about this data. Is it possible to insert/attach this pdf file to the form?
What would be the best way?
Cheers
Views
Total Likes
So are you trying to attached the PDF to another PDF? IS that Q&A form a PDF?
Jasmin
Views
Total Likes
Jasmin,
The QA form, which is a pdf, has been created by me and I would like to
1. either insert the pdf into my QA form or
2. attach it to the QA form.
I hope this makes it a bit clearer.
Cheers
Daniel
Views
Total Likes
Do you want the employee to attache the PDF to the D&A form or you want to do it server side?
We can do it in both cases.
Jasmin
Views
Total Likes
I would like the employee to attach the pdf to the form.
Daniel
Views
Total Likes
Well, then you can just use the attachment tab in Acrobat to attach a document to you pdf.
Jasmin
Views
Total Likes
Thanks Jasmin thats what we will do.
Just a follow on from this. Is there a way to create say a text field and the user of the form can "paste" a text in there which will expand to allow for the amount of lines pasted.
I will do some testing myself and see how I go
Thanks for all the help
Daniel
Views
Total Likes
If you create your PDF with LC Form Designer you can do that.
Check the expandToFit option.
Jasmin
Thanks Jasmin.
Gave that a run and works perfect. Thanks for all your help.
Cheers
Daniel
Views
Total Likes
