1 Reply Latest reply on Jun 7, 2010 2:25 AM by Bart Wouters
    Tree component customization
    Bart Wouters
      Hi all,
      I'm new to flex and having a hard time figuring out the best way to approach the following problem (in Flex context, _not_ AIR):
      I need a tree representation of some hierarchical/composite data structures as depicted below (for those familiar with XMLSpy, the diagram is similar to the XSD tree structure diagrams):
        | Child       |
        | child info  |
                                         |--| Child            |--------- Choice (x) ------|
                                         |  | Child Info      (x)                          |-------------|
                                         |  --------------------                           | Child       |
                                         |                                                 | child info  |
      | Parent      |------ Sequence (x)-|--| Child            |
      | Parent Info (x)                  |   | Child Info     (x)
                                         |--| Child            |
                                            | Child Info      (x)
      The (x) in the picture are the collapse/expand buttons.
      What would be the best way to approach this project ?
      - Is it a customization of the standard Tree component + custom Tree Item Renderer ?
      - The nodes should be expandable/collapsible + selectable (additional information to be displayed on selection of node without expand/collapse effect)
      - For the nodes would it make sense to derive them from the ToggleButton ? (and what would be the most sensefull way of introducing the second line on the button ? Or just building a proper graphical component for it (derived from Group)?
      - What is the most effective way to deal with the balancing of the tree in such a way that subtrees move out of the way/in place on expand resp. collapse of nodes ? (through (H/V)groups ?)
      - What would be the most efficient way to deal with the connectors between nodes ?
      - dataprovider would be an XML structure - what is the best place to put the building algo ? (Every node know how to create itself and the first level children ? Or a tree traverse on the XML structure, building all components in one go ?)
      Any advice/thoughts/references are welcome !
      Thanks in advance,
      Best regards,
      Bart
