4 Replies Latest reply on Jun 9, 2010 12:48 AM by netweasel
    How to work with SOAP responses?
    netweasel Level 1
      Hi everybody!
      I'm working with the new "import data" stuff and I'm stuck with the responses. It doesn't matter whether I try to get to the results over CallResponder.token.result oder CallResponder.lastResult, I simply get "undefined" values for both properties. But the ResultEvent.message property shows just the right response  SOAP message. How can I get a proper response out of this message?
      Regards and thanks
      Lukas
        • 1. Re: How to work with SOAP responses?
          Flex harUI Adobe Employee
          I am using lastResult when the result event is dispatched.
          • 2. Re: How to work with SOAP responses?
            netweasel Level 1
            Hi!
            Thanks for replying. This is what one is supposed to do. But in my case, lastResult is not defined. When introspecting a wsdl, fb4 creates all the value objects for the datatypes related to the given service. As I have understood, the lastResult should even be of type MyMethodResonse extending _Super_MyMethodResponse.
            • 3. Re: How to work with SOAP responses?
              Post your code.  Maybe you're not waiting for the result event?
              • 4. Re: How to work with SOAP responses?
                netweasel Level 1
                Ok, there you go.
                Script:
                protected function button_clickHandler(event:MouseEvent):void
                     loginRequest.Email = emailTextInput.text;
                     loginRequest.Password = passwordTextInput.text;
                     LoginResult2.token = profileServices.Login(loginRequest);
                protected function LoginResult2_resultHandler(event:ResultEvent):void
                     trace (event.message.body); //Returns the XML Message
                     trace (loginResponse);     //Returns null
                Markup Declarations:
                <profile:ProfileServices id="profileServices" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
                <profile2:LoginRequest id="loginRequest"/>
                <s:CallResponder id="LoginResult2" result="loginResponse = LoginResult2.lastResult as LoginResponse; LoginResult2_resultHandler(event); "/>
                <profile2:LoginResponse id="loginResponse">
                     <profile2:Result>
                          <profile2:ResultStatus/>
                     </profile2:Result>
                </profile2:LoginResponse>
                Markup Form:
                <mx:Form defaultButton="{button}">
                     <mx:FormItem label="Email">
                          <s:TextInput id="emailTextInput" text="{loginRequest.Email}"/>
                     </mx:FormItem>
                     <mx:FormItem label="Password">
                          <s:TextInput id="passwordTextInput" text="{loginRequest.Password}"/>
                     </mx:FormItem>
                     <s:Button label="Login" id="button" click="button_clickHandler(event)"/>
                </mx:Form>
                Thanks for having a look.
