3 Replies Latest reply on Jun 14, 2010 2:22 PM by goldensuits
    Combobox in ItemEditor
    goldensuits Level 1
      <datagrid>
      <itemeditor>
        <component>
         <box>
          <combobox id="foo" dataprovider={dprovider} text="{data.datafield} labelFiled={datafiedl} />
         </box>
        </component>
      </itemeditor>
      </datagrid>
      actionscript code
      object.data = event.currentTarget.itemEditorInstance.cbStat.selectedItem.datafield;
      the problem is, when I click on the cell in the datagrid, the combobox comes up, but with the first value of the dataprovider irrespective of the actual selected value and also gives a warning "unable to bind to property 'datafield' on class 'object'
      also tried     <combobox id="foo" dataprovider={dprovider}  selecteditem="{data.datafield} labelFiled={datafiedl} />
      same issue
      it works fine if I dont have the box around it
      is there something I am missing..?
      Thank you
        • 1. Re: Combobox in ItemEditor
          BhaskerChari Level 4
          Try to use the selectedIndex property of the ComboBox to set the selected item in the ComboBox but not the selectedItem property.
          Checkout the below code:
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
              <mx:Script>
                  <![CDATA[
              </mx:Script>
          <mx:ArrayCollection id="dp1">
                  <mx:Object firstName="Alex" enumValue="1"/>
                  <mx:Object firstName="Britanny" enumValue="2"/>
                  <mx:Object firstName="Charlie" enumValue="3"/>
                  <mx:Object firstName="Douglas" enumValue="1"/>
                  <mx:Object firstName="Eric" enumValue="2"/>
                  <mx:Object firstName="Frank" enumValue="2"/>
              </mx:ArrayCollection>
              <mx:Panel height="75%" width="75%"
                  paddingTop="10" paddingLeft="10" paddingRight="10" paddingBottom="10">
                  <mx:DataGrid width="100%" dataProvider="{dp1}">
                   <mx:columns>
                    <mx:DataGridColumn dataField="firstName" headerText="Name" />
                    <mx:DataGridColumn>
                     <mx:itemRenderer>
                      <mx:Component>
                       <mx:ComboBox creationComplete="setDDLSelectedItem();" width="100%" height="100%" labelField="HeightName" selectedItem="{data.enumValue}">
                        <mx:dataProvider>
                            <mx:Array>
                                <mx:Object HeightID="1" HeightName="Tall" />
                                <mx:Object HeightID="2" HeightName="Medium" />
                                <mx:Object HeightID="3" HeightName="Short" />
                            </mx:Array>
                        </mx:dataProvider>
                        <mx:Script>
                        <![CDATA[
                         import mx.collections.ArrayCollection;
                         private function setDDLSelectedItem():void
                          var ddlDP:ArrayCollection = this.dataProvider as ArrayCollection;
                          for(var intLoop:int=0;intLoop<ddlDP.length;intLoop++)
                           var v1:int = data.enumValue;
                           var v2:int = ddlDP.getItemAt(intLoop).HeightID
                           if(data.enumValue == ddlDP.getItemAt(intLoop).HeightID)
                            this.selectedIndex = intLoop;
                            break;
                       </mx:Script>
                    </mx:ComboBox>
                      </mx:Component>
                     </mx:itemRenderer>
                    </mx:DataGridColumn>
                   </mx:columns>
                  </mx:DataGrid>
              </mx:Panel>
          </mx:Application>
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: Combobox in ItemEditor
            goldensuits Level 1
            Hi Bhasker,
            Thank you for your response.
            When I use the selectedItem attribute it actually gives me the right value selected in the combobox populated, but when I click out of the grid it gives me an error
            heres the code
            dataprovider for the datagrid
            {name: "sample project", status_type: "progress"}
            dataprovider for the combobox
            {"hold", "progress", "closed"}
            so, the value "progress" is selected when clicked on the datagrid column status_type
            <datagriditemEditEnd="editEnd(event)" >
                 <columns>
                      <datagridcolumn dataFiled="name" />
                      <datagridcolumn dataFiled="status_type">
                           <itemeditor>
                                <component>
                                     <box>
                                          <combobox id="cbStat" dataprovider={outerDocument.status}" labelField="status_type" text="{data.status_type}" selectedItem="{data.status_type}" />
                                     </box>
                                </component>
                           </itemeditor>
                      </datagridcolumn>
                 </columns>
            </datagrid>
            <script>
            private function editEnd(event:DataGridEvent):void
                 var status = event.currentTarget.itemEditorInstance.cbStat.selectedItem.status_type;
            when I click on the datagrid column, the combobox comesup with the selected value, if I donot change the default value and click out of the grid, it errors out at the script code
            error: "Cannot access a property or method of a null object reference."
            If I change the value of the combobox and click out of the grid, it errors out at line: 4827 in DataGrid.as
            var newData:Object = itemEditorInstance[_columns[event.columnIndex].editorDataField];
            error:  "Property text not found on filename_inlineComponent2 and there is no default value"
            The same code works fine with no issues, if I do not have the <box> surrounding the combobox
            Is there something I am missing when using the inner components
            Thank you
            G
            • 3. Re: Combobox in ItemEditor
              goldensuits Level 1
              I have used combobox as a compnent item editor instead of a drop in, it worked fine
