0 Replies Latest reply on Jun 7, 2010 10:25 AM by SteveAuth
    Conditional build tags with character styles and ignored text
    SteveAuth
      • RoboHelp HTML v8.0.2.208
      • Windows XP Professional Version 2002 Service Pack 3 with 2 GB of RAM
      • Output: WebHelp and HTML Help
      I have recently moved my projects from RH HTML X5 to RH HTML 8 and this is when the following problem appeared. I use lots of conditional build tags within the help projects. Some of these tags are for my own use for reference and I combine these with character styles containing a coloured background (highlight) so that they show up in the WebHelp or HTML Help output (e.g. text to identify the software version that the field/feature/text was added, reminders to check details, insertion of bug ID numbers, design document names, etc.). These areas of text are stripped out of the final build for customers by using a conditional build expression.
      What I have noticed is that if a paragraph contains text with a conditional build tag applied AND that tagged text has a character style applied AND an unknown word within the conditional build tag is ignored (with the HTML tag <?rh-ignored text="word_to_be_ignored" ?>), saving the topic, closing it, then re-opening it shows that the conditional build text has stretched to the next conditional build tag, or to the end of the topic if there aren’t any other conditional build tags. This also happens by switching from Design View to HTML View. Note that this doesn’t happen if Ignore All is applied to the unknown word.
      This doesn’t just apply to projects converted from RH X5. I created a new test project in RH8 and the same behaviour was observed. Similar behaviour occurred very occasionally in RH X5 but that seemed to be down to HTML tags being nested incorrectly.
      The largest project contains around 1200 topics and with many hundreds of conditional build text areas this now causes a problem. I’ll probably have to locate every ignored word in an area of conditional text within each project, set it to Ignore All and then manually remove and re-apply the conditional build tags, unless someone can come up with something clever. Can anyone else replicate this and should it be logged as a bug?
