5 Replies Latest reply on Jun 8, 2010 10:32 PM by athiroy
    textinput value transfers one mxml file to another
    athiroy
      1. personal.mxml
      text input 1 : nametxt
              2:  addresstxt
                 3. submit button
      2. Family.mxml
      text input 1 : fathernametxt
              2:  mothernametxt
      ther user enter first personal.mxml
      he give the name and address then he selects submit button
      when submit button clicks it navigates
      http://localhost:8080/StudentRegistration/html/Family.html(Family.swf)
      then the user enter Fathername and mothername.
      here i want to transfer to uservo.as file
         nametxt, addresstxt,faternametxt,mothernametxt.
         but i cant get nametxt and addresstxt in Family.mxml
      anybody help me
      regards
      adhi
        • 1. Re: textinput value transfers one mxml file to another
          David_F57 Level 5
          hi,
          You can use shared objects they are like cookies, you save the data to the localdrive then the second swf can open the data.
          for a simple example of writing and reading shared objects look at the code of this example
          http://gumbo.flashhub.net/login/
          As you can see the mxml saves the data to a shared object, if you look at the creationcomplete you will see it reads the shared object so if it is there the information is available otherwise it will create the object. Writing (flush) of a shared object will store any data you want.
          David.
          • 2. Re: textinput value transfers one mxml file to another
            athiroy Level 1
            hi
            thnks for ur help
            i want to know how to retrive that shared object in another mxml file
            advance thanks
            regards
            athi
            • 3. Re: textinput value transfers one mxml file to another
              David_F57 Level 5
              hi,
              This is how it would work for your application, in the first mxml place the 'save' code into your submit function
              so in the first mxml
                          private function updateDetails():void
                                  var MyID:SharedObject = SharedObject.getLocal("SavedAddress","/");
              MyID.data.address = inputAddress.text;             }
              in the second applications mxml
                          protected function app_creationCompleteHandler(event:FlexEvent):void
                              address.text = MyID.data.address;             }
              • 4. Re: textinput value transfers one mxml file to another
                David_F57 Level 5
                hi,
                stupid forum ate the code.....
                first application add this to the submit routine
                   MyID.flush();
                second application have this in the creationcomplete routine
                • 5. Re: textinput value transfers one mxml file to another
                  athiroy Level 1
                  hi
                  i got output
                  thanks a lot
                  regards
                  adhi
