1 Reply Latest reply on Jun 16, 2010 1:50 AM by Devendran
    Adding two more Star Trails in movie clip
    xcmuddman Level 1
      Hi All,
      I bought a flash file the other day which i plan to modify and use for an intro to a project i am working on. Currently there is one instance of a Star which follows a path and emits "sparkles" while tracing the path. I would like to add two more stars/ paths. I tried modifying some of the code, and am working through it, but wanted to know if anyone could help me out a bit.
      import flash.filters.*;
      //--------------variables to change--------------------------//
      //modify the size of the sparkles
      var maxSparkSize:Number = 25;
      var minSparkSize:Number = 8;
      //set the speed the sparkles fade, 0 is never fade,the higher number quicker the fade
      var fadeSpeed:Number = 1//5;
      //speed which the sparkles fall, 0 is no fall, the higher the number the quicker the fall
      var fallSpeed:Number = 0.5;
      //the speed which the particles drift sideways. 0 gives no drift, positive numbers give right drift
      // negative numbers give left drift
      var windSpeed:Number = 0;
      //change the colour
      var randomColour:Boolean = true;
      defaultColour = 0xFFcc00;
      // the path to the followe_mc
      path = this.holder_mc.follower_mc;
      path = this.holder2_mc.follower2_mc;
      //you do not need to modify the code below here...
      var sparkle:Number = 0;
      var mousePosX:Number;
      var mousePosY:Number;
      var whichBat:Number;
      var count:Number = 0;
      //make the shape on top of the sparkles
      function startSparkles() {
                  this.onEnterFrame = function() {
                              var pathX:Number = path._x;
                              var pathY:Number = path._y;
                              xPos = randRange(pathX-2, pathX+2);
                              yPos = randRange(pathY-2, pathY+2);
      function createSparkle(xPos, yPos) {
                  movingSparkle = this.attachMovie("colouredSparkle", "s_"+sparkle, sparkle+10);
                  movingSparkle2 = this.attachMovie("colouredSparkle", "ss_"+sparkle, sparkle+101);
                              sparkle = 0;
      function setParams(movingSparkle){
                  //position the sparkle
                  movingSparkle._x = xPos;
                  movingSparkle._y = yPos;
                  //set initial size
                  movingSparkle._xscale = movingSparkle._yscale=Math.random()*maxSparkSize+minSparkSize;
                  movingSparkle._rotation = randRange(0, 360);
                  if (randomColour == true) {
                              col = Math.round(Math.random()*0xFFFFFF);
                  } else {
                              col = defaultColour;
                  colouredFill = new Color(movingSparkle.colour_mc);
                  colouredFill = new Color(movingSparkle.white_mc);
      function moveSparkle(movingSparkle) {
                  var rot = randRange(-15, 15);
                  var blurX = randRange(1, 5);
                  var blurY = blurX;
                  var blurFilter = new BlurFilter(blurX, blurY, 3);
                  //add some blur to the sparkle to make it softer
                  movingSparkle.white_mc.filters = [blurFilter];
                  //calculate the amount the sparkle will fade
                  var alphaDrop = randRange(1, fadeSpeed);
                  //commit the movements...
                  //this onEnterFrame moves the spark, rotates it, scales it and fades it.
                  movingSparkle.onEnterFrame = function() {
                              //change speed
                              this._y += fallSpeed;
                              this._x += windSpeed;
                              //change rotation
                              this._rotation = this._rotation+rot;
                              //make it smaller
                              this._xscale = this._yscale=this._xscale*0.98;
                              //fade the sparkle
                              this._alpha = this._alpha-alphaDrop;
                              //remove the movieclip if it get tiny
                              if (this._alpha<10) {
                              if (this._height<4) {
      function setColour(mc, col) {
                  colourIt = new Color(mc);
      function randRange(min:Number, max:Number):Number {
                  var randomNum:Number = (Math.random()*(max-min))+min;
                  return randomNum;
