1 Reply Latest reply on Jun 8, 2010 11:10 PM by Rdsingh Ldh
    how to send data from flex to java and vice versa using hashmap?
    Suman Biswas
      I am very new to Flex programming .So I have no idea about the topic mentined in the subject line.
      I have a requirement in which I have to send data as a HashMap from flex to java and similarly I need to send a hashmap bamoteck to flex.
      Any sample of code will be greatly helpful to me.
      Note-I am usiing RemoteObject to send the data to java.
      Thanks in advance,
      Suman
      email:suman.biswas@hcl.in
        • 1. Re: how to send data from flex to java and vice versa using hashmap?
          Rdsingh Ldh Level 1
          What I believe that data cannt be send from flex to java as hash maps...... we can send data from flex to java, but this data can be in form of array, string or boolean value..... Then the data can be send using ExternalInterface...............
          and if it is web application you need to use java script in between to communicate and if it is desktop application you can send data using MERAPI...
          MERAPI will act as a bridge for sending data from java to flex and vice versa... and you can send any type of data using merapi.
