3 Replies Latest reply on Jun 9, 2010 8:43 AM by asifdegr8
    Header Renderer for data grid
    asifdegr8
      I have populated datagrid based on XMLList as data provider. I have to make checkbox as header rendered in datagrid, when i click it should check all checkboxes in datagrid. I am also attaching the code for reference...
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
          </mx:Script>
          <mx:XMLList xmlns="" id="listdp">
                  <employee>
                      <firstName>Justin</firstName>
                      <lastName>Henin</lastName>
                      <recselected>true</recselected>
                  </employee>
                  <employee>
                      <firstName>Martina</firstName>
                      <lastName>Hingis</lastName>
                      <recselected>false</recselected>
                  </employee>
                  <employee>
                      <firstName>Serena</firstName>
                      <lastName>Williams</lastName>
                  </employee>
                  <employee>
                      <firstName>David</firstName>
                      <lastName>Becham</lastName>
                  </employee>
                  <employee>
                      <firstName>Rafael</firstName>
                      <lastName>Nadal</lastName>
                  </employee>
                  <employee>
                      <firstName>Roger</firstName>
                      <lastName>Federer</lastName>
                  </employee>
                  <employee>
                      <firstName>Kevin</firstName>
                      <lastName>Peterson</lastName>
                  </employee>
                  <employee>
                      <firstName>Jack</firstName>
                      <lastName>Russel</lastName>
                  </employee>
          </mx:XMLList>
          <mx:DataGrid x="35" y="10" id="mydg" dataProvider="{listdp}">
              <mx:columns>
                  <mx:DataGridColumn editable="true">
                      <mx:itemRenderer>
                          <mx:Component>
                              <mx:CheckBox selected="{data.recselected.text()=='true'?true:false}" click="{data.recselected = (data.recselected != 'true') ? 'true' : 'false';}"  />
                          </mx:Component>
                      </mx:itemRenderer>
                  </mx:DataGridColumn>
                  <mx:DataGridColumn headerText="Column 1" dataField="firstName"/>
                  <mx:DataGridColumn headerText="Column 2" dataField="lastName"/>
              </mx:columns>
          </mx:DataGrid>
      </mx:Application>
        • 1. Re: Header Renderer for data grid
          BhaskerChari Level 4
          you need to do something like below:
          I think its better to use arraycollection instead of XmlList as dataprovider for your Grid. This way it could be easy for you to accomplish your task.
          http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
              <mx:Script>
                  <![CDATA[
                      private function init():void
              </mx:Script>
                      <employee>
                      </employee>
                      <employee>
                      </employee>
                      <employee>
                      </employee>
                      <employee>
                      </employee>
                      <employee>
                      </employee>
                      <employee>
                      </employee>
                      <employee>
                      </employee>
                      <employee>
                      </employee>
              </mx:XMLList>
                  <mx:columns>
                      <mx:DataGridColumn editable="true" sortable="false">
                       <mx:headerRenderer>
                        <mx:Component>
                                  <mx:CheckBox click="checkUnCheckCheckBoxes()">
                                   <mx:Script>
                        <![CDATA[
                   private function checkUnCheckCheckBoxes():void
                    // Getting a reference to the outer XmlList listdp
                    var xmlList:XMLList = outerDocument.listdp;
                    var bool:Boolean = this.selected;
                    // If bool is true you need to check all check boxes else you need to uncheck all check boxes
                    // Here you need to write the logic to traverse through the XMLList
                    // listdp and chnage the recselected values for all to either true or false based on the hearder checkbox status
                    </mx:Script>
                                  </mx:CheckBox>
                              </mx:Component>
                       </mx:headerRenderer>
                          <mx:itemRenderer>
                              <mx:Component>
                                  <mx:CheckBox selected="{data.recselected.text()=='true'?true:false}" click="{data.recselected = (data.recselected != 'true') ? 'true' : 'false';}"/>
                              </mx:Component>
                          </mx:itemRenderer>
                  </mx:columns>
              </mx:DataGrid>
          </mx:Application>
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
          • 2. Re: Header Renderer for data grid
            Hi Asif,
            This is the working code for your application:
            I have converted the XMLList to XML and converted the XML to an ArrayCollection on creationComplete to accomplish this..
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
                <mx:Script>
                    <![CDATA[
                     import mx.rpc.xml.SimpleXMLDecoder;
                        [Bindable]
                        public var gridDP:ArrayCollection = new ArrayCollection();
                        [Bindable]public var headerSelected:Boolean = false;
                         var xml:XML = listdp;
                var xmlDoc:XMLDocument = new XMLDocument(xml);
                var decoder:SimpleXMLDecoder = new SimpleXMLDecoder(true);
                var obj:Object = decoder.decodeXML(xmlDoc);
                gridDP = obj.employees.employee as ArrayCollection;
                </mx:Script>
                <mx:XML id="listdp" format="e4x">
                  <employees>
                         <employee>
                         </employee>
                         <employee>
                         </employee>
                         <employee>
                         </employee>
                         <employee>
                         </employee>
                         <employee>
                         </employee>
                         <employee>
                         </employee>
                         <employee>
                         </employee>
                         <employee>
                         </employee>
                        </employees>
                </mx:XML>
                <mx:DataGrid x="35" y="10" id="mydg" dataProvider="{gridDP}">
                    <mx:columns>
                         <mx:headerRenderer>
                          <mx:Component>
                                    <mx:CheckBox selected="{outerDocument.headerSelected}" click="checkUnCheckCheckBoxes()">
                                     <mx:Script>
                          <![CDATA[
                      outerDocument.headerSelected = !outerDocument.headerSelected;
                      var gridDP:ArrayCollection = outerDocument.gridDP;
                      for(var i:int=0;i<gridDP.length;i++)
                       gridDP.getItemAt(i).recselected = bool;
                      gridDP.refresh();
                      </mx:Script>
                                    </mx:CheckBox>
                                </mx:Component>
                            <mx:itemRenderer>
                                <mx:Component>
                                    <!--<mx:CheckBox selected="{data.recselected.text()=='true'?true:false}" click="{data.recselected = (data.recselected != 'true') ? 'true' : 'false';}"/>-->
                                    <mx:CheckBox selected="{data.recselected}" click="{data.recselected = !data.recselected}"/>
                                </mx:Component>
                            </mx:itemRenderer>
                    </mx:columns>
                </mx:DataGrid>
            </mx:Application>
            Bhasker Chari
            • 3. Re: Header Renderer for data grid
              asifdegr8 Level 1
              Thanks Bhasker Chari ... my problem is solved ... you r da blessings in disguise
