• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Buffer overrun after recording?
New Here ,
Jun 09, 2010 Jun 09, 2010
When I do some recording in Captivate, since recently I get an error message after recording.
Steps:
  • Start recording, do what needs to be recorded
  • End recording
  • Captivate shows the "Importing..." dialog
  • Importing stops halfway through. Windows shows an error dialog "Adobe Captivate has stopped working / Windows can check online for a solution to the problem. / Check online for a solution and close the program/Close the program"
  • Details in this dialog are:
  Problem Event Name:                        BEX
  Application Name:                             AdobeCaptivate.exe
  Application Version:                           4.0.1.1658
  Application Timestamp:                     2a425e19
  Fault Module Name:                          businessrules.dll
  Fault Module Version:                        4.0.0.1596
  Fault Module Timestamp:                  494fe471
  Exception Offset:                                00003782
  Exception Code:                                  c0000409
  Exception Data:                                   00000000
  OS Version:                                          6.1.7600.2.0.0.256.48
  Locale ID:                                             2057
  Additional Information 1:                  b8e0
  Additional Information 2:                  b8e02f170de3c6a934bc729e9440511a
  Additional Information 3:                  2efb
  Additional Information 4:                  2efb2b5cafff69e217a1c94d92a6ff90
Some searching led me to the idea that Windows Data Execution Protection system has stopped Captivate, because of a buffer overrun (because of the Exception Code c0000409)
Captivate has been installed on that computer for 4 weeks, and earlier it worked. The problem only is present since a couple of days. The update for 4.0 has been installed.
Does anyone has a solution for this?
(there was a post with the same error in a different forum, but no solutions there)
Alex
TOPICS
Recording
Views
582
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Jun 14, 2010 Jun 14, 2010
We spent 4 days fiddling around with all kinds of settings, including disabling DEP, running as Administrator, running in Windows XP compatibility, disabling video acceleration, etc. Nothing helped.
It turned out that the Captivate project file (the thing we're working on) was corrupt in one way or the other. We created a new file, copied the slides, and now recording works again.
If anyone from Adobe cares to get the corrupt file, you can contact me. Can I get a voucher to upgrade to CP 5? 🙂
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
problem seems to be solved....
Votes
Translate
Translate
Report
Report
Resources
Help resources
