11 Replies Latest reply on Jun 14, 2010 12:47 PM by lkenney2
    Enable all Objects of a Class
    lkenney2 Level 1
      I'm trying to set up a a program where all instances of an extended Button class can be enabled or disabled at once.
      In other words, I have a class, TestButton.as, and in my Main class I'd like to be able to write TestButton.enabled = true for all instances of that class.
      I've being googling, but haven't managed to find the answer. Please help?
        • 1. Re: Enable all Objects of a Class
          msakrejda Level 4
          If you can control instantitation, you could create a buttonFactory, and when you create a button register the instance with something like a TestButtonManager class. Then use the TestButtonManager to control enabled / disabled state. If you can't control instantiation, you could add code to the TestButton constructor to register itself through some pre-defined static referenced (e.g., TestButtonManager.instance), although that's definitely a fishier solution (since it couples it to the manager). Alternately, you could bind the TestButton's enabled property to a static member variable on the TestButton class, but that's also kinda smelly...
          • 3. Re: Enable all Objects of a Class
            lkenney2 Level 1
            Hey msakrejda, thanks for the fast resonse. The first way you described is really unfamiliar sounding - would it be possible for you to go into some more details?
            Thanks.
            • 4. Re: Enable all Objects of a Class
              Gregor.Kiddie Level 2
              You could walk all the children on the display list, and test the type.
              Something like
              public function enableButtons( component : DisplayObjectContainer ) : void {
                  for ( var i : int = 0; i < component.numChildren; i++ ) {
                      if ( component.getChildAt( i )  is DisplayObjectContainer ) {
                          enableButtons( component.getChildAt( i ) );
                      } else if ( component.getChildAt( i )  is TestButton ) {
                          component.enable = true;
              Not exactly the most performant way of doing it, but it should work!
              • 5. Re: Enable all Objects of a Class
                msakrejda Level 4
                class TestButtonManager() {
                    private var _buttons:Dictionary = new Dictionary(true);
                    public function addButton(btn:TestButton):void {
                      _buttons[btn] = true;
                    public function toggleAll(enabled:Boolean):void {
                      for (var btn:Object /* note: can't declare this as TestButton due to mxmlc limitation*/ in _buttons) {
                        btn.enabled = enabled;
                class TestButtonFactory {
                    public static var manager:TestButtonManager = new TestButtonManager();
                    public static function createButton():TestButton {
                      var btn:TestButton = new TestButton();
                      manager.addButton(btn);
                      return btn;
                Something along those lines (this is quick and dirty, but this is the concept I was thinking of). Then instead of calling new TestButton(), just call TestButtonFactory.createButton(). If you're declaring your TestButtons in mxml, though, you can't do something like this (at least not today; I imagine support could be added for mxml component factories at some point).
                • 6. Re: Enable all Objects of a Class
                  jsd99 Level 3
                  I use a class I created called NotificationCenter for this purpose.  It's a very small class:
                  package com.jsd {
                       import flash.events.IEventDispatcher;
                       import flash.events.EventDispatcher;
                       public class NotificationCenter extends EventDispatcher {
                            private static var _dc:NotificationCenter = new NotificationCenter();
                            public function NotificationCenter(target:IEventDispatcher=null) {
                                 super(target);
                            public static function get defaultCenter():NotificationCenter {
                                 return _dc;
                  So everytime you create one of your TestButtons, you would do:
                  NotificationCenter.defaultCenter.addEventListener(TestButton.ENABLE_ALL, enableMyself);
                  NotificationCenter.defaultCenter.addEventListener(TestButton.DISABLE_ALL, disableMyself);
                  You obviously have to provide the enableMyself/disableMyself methods, and the ENABLE_ALL/DISABLE_ALL static strings for TestButton.
                  Then later on when you want to enable them all, you can do this from anywhere else in your application:
                  NotificationCenter.defaultCenter.dispatchEvent(new Event(TestButton.ENABLE_ALL));
                  • 7. Re: Enable all Objects of a Class
                    Shongrunden Adobe Employee
                    If you prefer to work in MXML you could take advantage of data binding and do something like this:
                    CustomButton.mxml:
                    <s:Button xmlns:fx="http://ns.adobe.com/mxml/2009"
                              enabled="{CustomButton.allButtonsEnabled}">
                        <fx:Script>
                            <![CDATA[
                                [Bindable] public static var allButtonsEnabled:Boolean = true;
                        </fx:Script>
                    </s:Button>
                    Then to disable all CustomButtons you would set CustomButton.allButtonsEnabled = false
                    • 8. Re: Enable all Objects of a Class
                      GordonSmith Level 4
                      Can't you just do something simple like this?
                      class MyButton
                          static var instances:Array = [];
                          public function MyButton()
                              super();
                              instances.push(this);
                          public static function set enabled(value:Boolean):void
                              var n:int = instances.length;
                              for (var i:int = 0; i < n; i++)
                                  instances[i].enabled = value;
                      Gordon Smith
                      Adobe Flex SDK Team
                      • 9. Re: Enable all Objects of a Class
                        msakrejda Level 4
                        Well, I think that definitely strips all my overengineering out of it. The only thing I'd change is to make instances a weak-key Dictionary instead of an Array, or you'll leak button instances once they're removed from the display list.
                        • 10. Re: Enable all Objects of a Class
                          GordonSmith Level 4
                          Good point!
                          Gordon Smith
                          Adobe Flex SDK Team
                          • 11. Re: Enable all Objects of a Class
                            lkenney2 Level 1
                            Hi jsd. In the end, this wasn't quite what I did, but it was very clode, so I'd like to thank you for helping me out. I ended up using an extended event class with the ability to carry a variable, and an extended eventdispatch class with my dispatch functions. I.e. see below:
                            public function enableAbortButton(isTrue:Boolean):void {
                                        dispatchEvent(new EduSpeakEvent(EduSpeakEvent.ENABLE_ABORT_BUTTON, {data:isTrue}));
                            In the button class I wanted to enable, I created an instance of the extended event dispatcher and added an event listener:
                            public function EduSpeakAbortButton()
                                        label = "Abort";
                                        displayLoader = new EduSpeakEventDispatch();
                                        displayLoader.addEventListener(EduSpeakEvent.ENABLE_ABORT_BUTTON, enableAbortButton);
                                    private function enableAbortButton(e:EduSpeakEvent):void
                                        this.enabled = e.param.data;
                            And whenever I wanted to enable or disable the buttons, I created an instance of the event dispatcher and used the associated method:
                            displayLoader.enableAbortButton(true);
                            This seems to be working. So thanks, I couldn't have figured it out without you!
