I'm using a button with the submit control type to submit a form by email. I used the mailto protocol with my email address in the "Submit to URL:" field, but when I click the button on the completed form, it either does nothing or sometimes it will say it is looking for a file on the hard drive with the mailt:xxx@xxx.com as part of the path. I need the form to submit as a pdf, so I can't just use the Email Submit Button.
Why isn't it working and what do I do to fix it?
Thank you!
Views
Total Likes
The mailto will not change the fact that you cannot submit the PDF ...it will also only submit XML. You will have to Reader Extend the form to allow a local save before you can submit a PDF.
Back to the mailto .....do you have a mail client on your machine (liek Outlook or Thunderbird) or do you access your mail through a web address (like gmail or yahoo)?
Paul
Views
Total Likes
For this particular project I am using Outlook. I also use Thunderbird though, and web mail.
What do I do to Reader Extend the form?
Views
Total Likes
If you have Acrobat you can open the form in Acrobat and under the Advanced menu selct the Extend Features in Adobe Reader option. Just follow the wizard, then use the resulting PDF that is created.
The other option is to get a server product called LiveCycle Reader Extensions but this woudl be overkill for what you have described.
If you do not have Acrobat, I suggest you get a trial version from the Adobe web site and validate that it will fix your problem. If it does then buy one copy so you can Reader Extend your forms.
Hope that helps
Paul
Views
Total Likes
