1 Reply Latest reply on Aug 17, 2015 11:20 PM by Chen Jue
    Additional Compiler Arguments - How to set?
    asafdsadfasddfsas Level 1
      In FlexBuilder, go to project properties and navigate to the Flex Compiler. You should see an "Additional Compiler Arguments" field.
      If I build the flex application through Ant How to set the same? Please explain in detail the file where I need to set with an example for setting "-locale en_US".
        • 1. Re: Additional Compiler Arguments - How to set?
          Chen Jue
          in the target field in the build.xml file, such as:
            <target name="compile.app">
                   <mxmlc file="${project.src.dir}/a.as"
                       output="${project.release.dir}/a.swf"
                       actionscript-file-encoding="UTF-8"
                       debug="true" fork="true">
                       <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml" />
                       <source-path path-element="${project.src.dir}" />
                       <external-library-path dir="${FLEX_HOME}/frameworks/libs">
                           <include name="player/12.1/playerglobal.swc" />
                           <include name="datavisualization.swc" />
                           <include name="framework.swc" />
                           <include name="rpc.swc" />
                       </external-library-path>
                       <library-path dir="${project.libs.dir}" append="true">
                           <include name="*.swc" />
                       </library-path>
                       <jvmarg line="${mxmlc.jvm.args}"/>
                      <arg value="-locale"/>
                       <arg value="en_US"/>
                   </mxmlc>
               </target>
