1 Reply Latest reply on Jun 9, 2010 10:14 PM by Rdsingh Ldh
    passing data between components
    tuliptaurus Level 1
      I am using a base component which has been extended to 2 other components. the base component has all the scripts. and the child components utilise the scripts in the base component. the variables have been set to bindable and public in base component.
      But when I click some panel or select a radio button in the child component i get the error  ReferenceError: Error #1065: Variable advanceSelectionCPanel is not defined.
      How do i correct this error
      am new to flex
        • 1. Re: passing data between components
          Rdsingh Ldh Level 1
          Are you using the reference of the base
          component to access the variable that you have defined in the base component.....
          If the component where you have decalred the variables is your application class of the application then you can use
          Application.application.advanceSelectionCPanel
