1 Reply Latest reply on Jun 10, 2010 6:56 AM by Kasyan Servetsky
    set bleed top to 2inch--indesign cs4
    Poo_Del Level 1
      Hi All,
      I am using below syntax for exporting PDF with my own preset. I want to change the value of bleed top to 2 inch. Then I want to export the PDF.
      Please suggest how can I do that.
      Applescript:
      tell application "Adobe InDesign CS4"
      tell PDF export preferences
      set bleed top to "2in"
      end tell
      tell document 1
      export format PDF type to "Macintosh:Test.pdf" using myPresetName without showing options
      end tell
      end tell
      Please let me know where I am doing mistake.
      Regards,
      Poo
        • 1. Re: set bleed top to 2inch--indesign cs4
          Kasyan Servetsky Level 5
          If I don't indicate preset name on export this code works for me:
                    set bleed top to "2 in"
               end tell
               tell document 1
                    export format PDF type to "Macintosh HD:Test.pdf" without showing options
               end tell
          end tell
          Probably preset overrides this setting.
          Kasyan
