11 Replies Latest reply: Jun 11, 2010 11:48 AM by Abram Adams RSS
    Query of Queries With Date Strings
    Dan Bracuk Community Member
      Running cold fusion 9
      database query, from oracle, includes this in the select clause
      , to_Char(DateRequested, 'yyyy-mm-dd') thedate
      so it's a string.
      Then we have a url variable.  It's called thedate and the value is 2010-06-09.
      The objective is to get the record from the oracle query that matches the url variable.
      But this code:
      <cfquery name="ThisResource" dbtype="query">
      select FundingResourceId, status, thedate
      from PatientResources
      where thedate = <cfqueryparam cfsqltype="cf_sql_char" value="#url.thedate#">
      </cfquery>
      will not return any rows.  This includes many attempts that included hard coding the value, checking for white space, etc.  Nothing I tried returned the row.  However, when I changed this:
      to this
      where thedate LIKE <cfqueryparam cfsqltype="cf_sql_char" value="#url.thedate#">
      it returned the expected record.  Note that I didn't even need a wildcard.
      Anybody have any thoughts on this?
        • 1. Re: Query of Queries With Date Strings
          BKBK Community Member
          Perhaps empty space at the end of the URL? If so, then trim(url.thedate) should do the trick. In any case, why not use varchar instead?
          • 2. Re: Query of Queries With Date Strings
            I tried using varchar.  It didn't affect the results.  I checked for whitespace around the "thedate" column in the query result but not in the url variable.  However, if that was the issue, I would think that the query would have returned the record with the hard coded value, but it didn't.
            Bear in mind that I am looking for opinions more than help.  Replacing the equal sign with the like keyword solved my immediate problem.  It just bugs me that something that I think should have worked, didn't.
            • 3. Re: Query of Queries With Date Strings
              yui8979 Community Member
              Hardcode the 'thedate' results in PatientResources as well, ie, select
              blah1,blah2,thedate='2010-02-11' , does your QOQ work then?
              • 4. Re: Query of Queries With Date Strings
                I see in the documentation that the argument DateRequested should be an Oracle date object. Is it?  What about createODBCDate(DateRequested) instead? Could there be some conversion going on between cfqueryparam and URL, like - being converted into %2D and back?
                • 5. Re: Query of Queries With Date Strings
                  Like this?
                  x (Datasource=cmpi, Time=0ms, Records=1) in D:\DW\dwtest\Dan\abc.cfm @ 08:16:41.041
                  select '2010-06-11' y
                  from dual
                  z (Datasource=, Time=16ms, Records=0) in D:\DW\dwtest\Dan\abc.cfm @ 08:16:41.041
                  select * from x where y = '2010-06-11'
                  and the same thing with mssql
                  x (Datasource=kidcare, Time=47ms, Records=1) in D:\DW\dwtest\Dan\abc.cfm @ 08:18:58.058
                  z (Datasource=, Time=0ms, Records=0) in D:\DW\dwtest\Dan\abc.cfm @ 08:18:58.058
                  • 6. Re: Query of Queries With Date Strings
                    DateRequested is an oracle date object and to_char returns a string.  cfqueryparam does not appear to matter because I get the same results without it.
                    • 7. Re: Query of Queries With Date Strings
                      Adam Cameron. Community Member
                      You might find that when you use CHAR columns / data, it will be space-padded by Oracle (so won't be showing up in your examination of whether there's extra whitespace) to be the specified length of the column (char data is fixed-length), which you won't really want.  Use a VARCHAR.
                      Dunno why the LIKE is working, but.
                      Adam
                      • 8. Re: Query of Queries With Date Strings
                        Quite a satisfactory response.
                        • 9. Re: Query of Queries With Date Strings
                          Not currently on Oracle myself, but this sounds plausible.
                          • 10. Re: Query of Queries With Date Strings
                            And with a cold fusion query:
                            <cfscript>
                            q = QueryNew("s","varchar");
                            x = QueryAddRow(q, 1);
                            x = QuerySetCell(q, "s", "2010-06-10");
                            </cfscript>
                            <cfquery name="z" dbtype="query">
                            select s from q
                            where s = '2010-06-10'
                            </cfquery>
                            <cfdump var="#q#" metainfo="no" label="q">
                            <cfdump var="#z#" metainfo="no" label="z">
                            q - query
                            S
                            12010-06-10
                            z - query
                            S
                            • 11. Re: Query of Queries With Date Strings
                              Abram Adams Community Member
                              This looks like a bug to me.  I tried your example and got the same results in CF8 and CF9, though it works as expected in Railo...
                              It seems like it's trying to guess that you really wanted that to be a date.  Change your example from
                              to
                              q = QueryNew("s");
                              And you'll see:
                              q - query
                              S
                              1
                              {ts '2010-06-10 00:00:00'}
                              z - query
                              S
                              1
