3 Replies Latest reply on Jun 10, 2010 8:45 AM by future-architect
    future-architect Level 1
      when i use the gradient tool, it only allows me to choose the gradient type.  i cannot change the color.  how do i change the color of this without having to backup?
        • 1. Re: changing
          Linda Nicholls Level 4
          See the little color boxes at each end of the gradient ramp?If you click on those a swatches palette and color picker open. The top boxes are for adjusting the opacity.
          • 2. Re: changing
            pixlor Level 4
            Linda's answered your question, but to add to that...
            You can also click along the bottom of the gradient to add more color squares and make a gradient with more than two colors. Once you do that, you can click on an added square to slide it horizontally, changing the proportions of the colors.
            And... That vertical line you show with the circle at one end and the square at the other? You can click those and drag them anywhere. The line sets the direction of the gradient; and the points set the starting and ending boundaries. They can be within your object, making your gradient over a portion of the object, or they can be outside your object, which can sometimes handy.
            • 3. Re: changing
              whoa, neat, thanks everybody!!! (:
