0 Replies Latest reply on Jun 10, 2010 8:25 AM by CRez79
    Spacing the underline under text
    CRez79 Level 1
      Hi, banging my head on this one. I found solutions but it seems to only work in the non-flex environment. Was nice to see the simularities between flex's css and typical css, but this one isn't so transferable.
      I have a button that I'm styling, and I want to increase the space between the bottom of my text and the underline. By using the CSS
      text-decoration: underline;
      you can underline elements in both standard CSS/Html as well as Flex. But if you want to increase the space in CSS/Html you just use
      padding: 2px;
      border-bottom: 1px solid #aaaaaa;
      but if I try this in Flex, it fails. I do not see any border under the text. I even tried negative padding, wider borders, different colors, but I just can't get the normal CSS solution to work with Flex CSS. Here is the code I'm trying to get the affects on.
      example below
      test3 - displays the standard underline
      test4 - uses a method to try and display an underline but with increased space between the text and the line.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="horizontal">
      <mx:Style>
      Button {
      skin: ClassReference(null);
      text-roll-over-color: #2EAAC2;
      font-size: 13pt;
      color: #2E6DC2;
      border-bottom: 3px solid #AA22AA;
      padding-bottom: 2;
      .test3 {
      font-size: 13pt;
      color: #2E6DC2;
      text-decoration:underline;
      .test4 {
      font-size: 13pt;
      color: #2E6DC2;
      padding-bottom: 2;
      </mx:Style>
      <mx:Style source="main.css"/>
      <mx:Button id="test2" label="2. Testing"/>
      <mx:Label id="test3" text="3. Testing" styleName="test3" />
      <mx:Label id="test4" text="4. Testing" styleName="test4" />
      </mx:Application>
