1 Reply Latest reply on Aug 23, 2010 6:34 AM by Dieter Dubai
    ddx - labelLayers
    Beetlevw19741234
      Morning,
      Has anyone used this with ddx? I am playing.
      Trying to get a document where I am assembling two documents and getting layers to work.
      I am assuming I am way off.
      Does anyone have a working sample?
      <DDX xmlns="http://ns.adobe.com/DDX/1.0/">
        <InitialViewProfile name="initialViewProfile1" display="DocumentTitle"/>
        <PDF result="result" initialView="initialViewProfile2">
          <PDF source="doc2" layerLabel="doc2"/>
          <PDF source="doc1" layerLabel="Help"/>
        </PDF>
        <InitialViewProfile name="initialViewProfile2" show="LayersPanel"/>
        <?ddx-source-hint name="doc2"?>
        <?ddx-source-hint name="doc1"?>
      </DDX>
      Carmen
        • 1. Re: ddx - labelLayers
          Dieter Dubai Level 1
          I am not sure what exactly you want ot achive.
          There is a mergeLayers option which would merge setting to 'true' all layers in the result, by setting to 'false' retain the layers.
          false (default) - Layers from different source documents are kept distinct in the assembled document. If the layerLabel attribute in the source document is specified, the names are modified by the label; otherwise, the layers keep the same names.
          rgs
          Dieter
