3 Replies Latest reply on Jun 11, 2010 2:53 AM by Kasyan Servetsky
    Batch relink images in InDesign CS4
    Alexander Scherling
      Hi all your InDesign wizkids.
      I have a document with 800 image links that all have changed location and filename.
      all instances have a product number as filename. They have now been changed.
      so filename was eg. changed from --> to:
      123456.tif  -->  1203456.tif
      112233GB.tif  --> 1102233GB.tif
      79657.tif     -->     790657.tif
      13657NHZ.tif -->     130657NHZ.tif
      The only change is that there have been added a 0 as third digit.
      Also it would be cool to update path in same action to some/new/folder/to/file
      It would be a major help if any one could solve this.
      Best regards
      Alexander
        • 1. Re: Batch relink images in InDesign CS4
          brettpolo Level 1
          Should be very easy to do if the only diffrence is that there is a '0' inserted after the second character...
          something like the following should work:
          newPath = "/your/new/path/here"
          myLinks = app.activeDocument.links
          for (i = 0; i < myLinks.length; i++){
               var oldName = myLinks[i].name;
               var newName = oldName.slice(0,2) + "0" + oldName.slice(2);
               myLinks[i].relink(newPath+newName)
          replace 'newPath' with the path the new links will be in.
          • 2. Re: Batch relink images in InDesign CS4
            Alexander Scherling Level 1
            Thanks a lot.. it looks really good, but doesn't seem to work..
            The ExtendScript toolkit just keeps running (15 min) on a test doc i made with 20 links.
            What is wrong?
            Was it possible to make script without relink, so i just do that from the linkspalette??
            Here is script:
            newPath = "smb://sql-srv/marketing$/Marketing/TOOLBOX/Pictures/PACKSHOTS/Charms/TIFF CMYK/"
            • 3. Re: Batch relink images in InDesign CS4
              Kasyan Servetsky Level 5
              Try to set newPath variable like so:
              var newPath = "/Volumes/sql-srv/marketing$/Marketing/TOOLBOX/Pictures/PACKSHOTS/Charms/TIFF CMYK/";
              I assume that sql-srv is a mounted volume on your desktop.
              Kasyan
