1 Reply Latest reply on Jun 10, 2010 10:19 AM by David_F57
    Is it possible to have a transparent bg?
    adamgeework Level 1
      something like what you can export in flash so you can see the browser's background.
        • 1. Re: Is it possible to have a transparent bg?
          David_F57 Level 5
          hi,
          you normally do this through the html template, there are 2 places that this could work usually you should get the transparency by going into the
          index.template.html add the 2 lines as hilited in red. Clean your project just to make sure that it will recreate your project html next time you do a build. Don't forget to set the application background alpha to 0
                  <script type="text/javascript" src="swfobject.js"></script>
                      <!-- For version detection, set to min. required Flash Player version, or 0 (or 0.0.0), for no version detection. -->
                      var swfVersionStr = "${version_major}.${version_minor}.${version_revision}";
                      <!-- To use express install, set to playerProductInstall.swf, otherwise the empty string. -->
                      var xiSwfUrlStr = "${expressInstallSwf}";
                      var flashvars = {};
                      var params = {};
                      params.quality = "high";
                      params.bgcolor = "${bgcolor}";
                      params.allowscriptaccess = "sameDomain";
                      params.allowfullscreen = "true";
                     params.wmode="transparent";
                      var attributes = {};
                      attributes.id = "${application}";
                      attributes.name = "${application}";
                      attributes.align = "middle";
                      swfobject.embedSWF(
                          "${swf}.swf", "flashContent",
                          "${width}", "${height}",
                          swfVersionStr, xiSwfUrlStr,
                          flashvars, params, attributes);
          <!-- JavaScript enabled so display the flashContent div in case it is not replaced with a swf object. -->
          swfobject.createCSS("#flashContent", "display:block;text-align:left;");
                  </script>
              </head>
              <body>
                  <!-- SWFObject's dynamic embed method replaces this alternative HTML content with Flash content when enough
          JavaScript and Flash plug-in support is available. The div is initially hidden so that it doesn't show
          when JavaScript is disabled.
                  <div id="flashContent">
                  <p>
                  To view this page ensure that Adobe Flash Player version
          ${version_major}.${version_minor}.${version_revision} or greater is installed.
          </p>
          var pageHost = ((document.location.protocol == "https:") ? "https://" : "http://");
          document.write("<a href='http://www.adobe.com/go/getflashplayer'><img src='"
          + pageHost + "www.adobe.com/images/shared/download_buttons/get_flash_player.gif' alt='Get Adobe Flash player' /></a>" );
          </script>
                  </div>
                 <noscript>
                      <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="${width}" height="${height}" id="${application}">
                          <param name="movie" value="${swf}.swf" />
                          <param name="quality" value="high" />
                          <param name="bgcolor" value="${bgcolor}" />
                          <param name="allowScriptAccess" value="sameDomain" />
                          <param name="allowFullScreen" value="true" />
                         <param name="wmode" value="transparent"/>
                          <!--[if !IE]>-->
                          <object type="application/x-shockwave-flash" data="${swf}.swf" width="${width}" height="${height}">
                          <!--<![endif]-->
                          <!--[if gte IE 6]>-->
                          <p>
                          Either scripts and active content are not permitted to run or Adobe Flash Player version
                          ${version_major}.${version_minor}.${version_revision} or greater is not installed.
                          </p>
                          <!--<![endif]-->
                              <a href="http://www.adobe.com/go/getflashplayer">
                                  <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash Player" />
                              </a>
                          <!--[if !IE]>-->
                          </object>
                          <!--<![endif]-->
                      </object>
              </noscript>
             </body>
