3 Replies Latest reply on Jun 12, 2010 2:02 AM by Bernd Alheit
    Problem with API (429 Error)
    M_Dem_1380 Level 1
      Hello,
      I want to achieve a really simple OLE automation using acrobat reader using VBA :
      I try the case with Reader version 7.0, 8.0, 9.0, problem remains the same.
      I try the case with Windows 2003, Windows XP SP3, Windows 7.
      I work with Office 2003.
      So very, very simple case :
           - Start VB express 2008 or VBA (into office)
           - Reference the good abode library COM types : Adobe Acrobat x.x types library (also tried all others)
           - Write
                Dim Var as Acrobat.app (syntax is different according tool you use but remains tool driven)
                set var  =  createobject("Acroexch.app")
                and you got a 429 activeX cannot create object error
      I donwloaded the SDK. Didn't find something in documentation and even sample given don't work.
      I can tell you that other OLE automation server is working properly as far as I can automate thing with others providers/servers.
      So I someone see a solution, it would be helpfull.
        • 1. Re: Problem with API (429 Error)
          Bernd Alheit Adobe Community Professional & MVP
          This OLE interface is available with Adobe Acrobat, not Adobe Reader.
          • 2. Re: Problem with API (429 Error)
            M_Dem_1380 Level 1
            Thanks for answer.
            It is still currently unclear for me what could be de difference between Adobe Acrobat and Abode Reader, but
            I presume this is a money question ;-)
            In any case thank you for that answer, I will further investigate.
            Regards.
            PS :     In any case I would add something - regarding Adobe :
                       When I found the SDK, I went through links following acrobat. I never view (or missed) any mention of reader or not ;-) This is unclarity.
                       Maybe I missed everything even in SDK but in any case this could be more vlearly explained.
                       I am not that kind of beginner I see the messages on the web : go and search questions
                       and (.. none ... ?) answer, you will understand what I mean).
                       I work in a professional and structured way AND
                       If answer is true, I find that it should be more clear to avoid waste of time of many people that are not playing geeks.
                       Regards
            • 3. Re: Problem with API (429 Error)
              Read the section 'Introduction to SDK' in the Acrobat SDK. For the use of Adobe Reader read the subsection 'Developing for Adobe Reader'.
