5 Replies Latest reply on Jun 17, 2010 8:23 AM by the_wine_snob
    plug-ins to boost volume in PE7
      I have a clip on my timeline in PE7 that sounds very low compared to the next clip; I've tried adding multiple layers of volume from Effects tab and that didn't work.  I tried experimenting Balance and all of the other elements on the Audio Effects tab but no luck.
      Is there a technique, plug-in or free or shareware I can use to increase the volume on the audio clip and reconnect it to the video?
        • 1. Re: plug-ins to boost volume in PE7
          the_wine_snob Level 9
          There are several ways to boost the Audio Levels in PrE. Most are Clip related, and one is Track related.
          I'll outline them, but think that you may have used the first already, and it is not enough.
          1.) Click the Clip to Select it, and then in the fixed Effect Volume, raise the Level. This will basically add a Keyframe to increase the Volume.
          2.) Rt-click on the Clip, and choose Audio Gain in the flyout menu
          3.) With Audio Mixer (Window>Audio Mixer), you can adjust the Levels, but this is Track-level, so if the Clip is replaced, those adjustments are still there on the Track.
          One can also Export Audio and then Import it into an audio editor, like Audition, or the free audio-editor, Audacity, to adjust the Amplitude of the piece, and just replace the original with that edited version, from when you do a Save_As. Those programs, can also rip the Audio from your AV file, to save having to do the Export.
          • 2. Re: plug-ins to boost volume in PE7
            I second what Hunt says about using Audio Gain.
            Right-click on your clip and select the Audio Gain option. If you click the Normalize button, it should automatically raise the level of your audio's gain and thus increase its volume. If you need to manually increase it more, you can do so by typing in even larger numbers for the gain level.
            • 3. Re: plug-ins to boost volume in PE7
              P_Forrest Level 1
              TIP:  Often when you raise the gain (or volume) of a clip, you might hear more background "hiss."  Luckily, PE 7 has a DENOISER audio effect that does a very nice job of removing major hiss issues.
              PE 7
              • 4. Re: plug-ins to boost volume in PE7
                4anue Level 1
                Thanks guys.  Audio gain did the trick.
                Antoinette Nue
                The Green Living Goddess
                Interested in going green but not sure where to start?  I can help
                Want answers to The Most Frequently-asked Questions About Going Green?
                • 5. Re: plug-ins to boost volume in PE7
                  Glad that Audio Gain did the job for you.
                  For future productions, you might want to look into a different mic, or increase the gain a little, during the recording process - be careful, however, to not over-do that, as you do not want ANY peaks over 0dB, or Clipping will occur.
