5 Replies Latest reply: Jun 11, 2010 1:55 AM by Adam Cameron. RSS
    cfloop and cfoutput creates carriage return in RSS Feed
    Ronsweb Community Member
      I am having problems with validation of a RSS Feed that I am creating using CFXML. I have tried both cfoutput and cfloop and is creating the following:
            <item>
              <title>Events: career panel on Career Options with a Library Technician Certificate</title>
              <link>http://events.lbcc.edu/detail.cfm?eventid=1286</link>
              <description>The Library Department &amp; LAC Career &amp; Job Services Center will host a career panel on Career Options with a Library Technician Certificate. 11:00 a.m. to 1:00 p.m. in Building E - Student Center. </description>
            </item>
                                                               <---------------------- cfloop and cfoutput is Adding carriage return creating a non valid rss feed.
            <item>
              <title>Events: EOPS applications will be available beginning May 3</title>
              <link>http://events.lbcc.edu/detail.cfm?eventid=1273</link>
              <description>Due to increased FAFSA application volume in Financial Aid, EOPS applications will be available beginning May 3.For further questions please call 562-938-4772 (LAC) or 562-938-3097 (PCC).</description>
            </item>
      If I use cffeed the xml is working correctly as follows and creates a valid feed:
            <item>
            </item>
            <item>
            </item>
      Here is my code:
      <cfcomponent output="false">
      <cffunction name="UpdateRSSFeed" access="remote" returntype="void">
      <cfset RSSXMLPath = "e:\websites\www\RSSFeed\">
      <!--- Create All News and Events Feed--->
      <cfinvoke component="eventsystem" method="listAllNewsEvents" returnvariable="listAllNewsEventsRET">
      <cfoutput>
           <cfxml variable="AllNewsEventsFeed">
            <rss xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns##" xmlns:itunes="http://www.itunes.com/dtds/podcast-1.0.dtd" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:taxo="http://purl.org/rss/1.0/modules/taxonomy/" version="2.0">
              <channel>
              <title>News and Events RSS Feed</title>
              <link>http://www.lbcc.edu/</link>
              <cfloop query="listAllNewsEventsRET">
                <item>
                  <title><cfif listAllNewsEventsRET.event_typeID eq 2>News:<cfelse>Events:</cfif> #XMLFormat(listAllNewsEventsRET.Event_Title)#</title>
                  <link>#listAllNewsEventsRET.FullLink#</link>
                  <description>#XMLFormat(listAllNewsEventsRET.summary)#</description>
                </item>
              </cfloop>
             </channel>
             </rss>
            </cfxml>
          </cfoutput>
          <!--- Write to file --->
           <cffile
                action="write"
                addnewline="no" charset="us-ascii"
                file="#RSSXMLPath#NewsEvents2.xml"
                output="#ToString(AllNewsEventsFeed)#" fixnewline="no">
      </cffunction>
      </cfcomponent>
      Any suggestions would be appreciated.
      Thanks.
      Ron
        • 1. Re: cfloop and cfoutput creates carriage return in RSS Feed
          ilssac Community Member
          They don't "create" carraige returns.  They send each and every one that is is in your code if is is between an <cfoutput> opening and </cfoutput> closing tag.  Even the very first one that is right after the <cfoutput> tag itself.
          ColdFusion offers many ways to help you control whitespace in your document.  Some of the major features are the <cfsilent></cfsilent> tag, <cfsetting enablecfoutputonly=true> tag, <cfprocessingdirective  suppressWhiteSpace="true"></cfprocessingdirective> tag, etc.
          But I suspect that your problem may be as simple as removing the offending line break from your code.  I often start my xml output somehting like this:
          <cfoutput><myXmlRoot>
          <!---other xml tags follow below--->
          • 2. Re: cfloop and cfoutput creates carriage return in RSS Feed
            Ian,
            Thanks for the reply.  I already tried <cfsilent></cfsilent> tag, <cfsetting enablecfoutputonly=true> tag, <cfprocessingdirective  suppressWhiteSpace="true"></cfprocessingdirective> to no end.
            The white space is where the cfloop tag is.  The code is located above.
            Ron
            • 3. Re: cfloop and cfoutput creates carriage return in RSS Feed
              And there is a carriage return at the end of the <cfloop...> line is there not!
              <cfloop query="listAllNewsEventsRET"> <-- this is a carriage return!
              <item>
              <cfsetting enablecfoutputonly=true> is not going to do much if you just use one big <cfoutput> around all the code you want to output AND all the white space you do not.  To effectiviely use this one you would need to do something like this.
              <cfoutput><channel>
              <link>http://www.lbcc.edu/</link></cfoutput>
              <cfoutput><item>
              <title><cfif listAllNewsEventsRET.event_typeID eq 2>News:<cfelse>Events:</cfif>#XMLFormat(listAllNewsEventsRET.Event_Title)#</title>
              </item></cfoutput>
              </cfloop>
              <cfoutput></channel>
              </rss></cfoutput>
              </cfxml>
              • 4. Re: cfloop and cfoutput creates carriage return in RSS Feed
                Adam Cameron. Community Member
                And, probably most importantly for this situation, setting OUTPUT="FALSE" on the <cffunction> tag.
                Adam
                • 5. Re: cfloop and cfoutput creates carriage return in RSS Feed
                        <item>
                        </item>
                  Another thing... there is absolutely no problem with having whitespace in an RSS feed like this.  What validation is it failing?
                  Adam
