1 Reply Latest reply on Jun 10, 2010 2:55 PM by jsd99
    SecurityError:2148:Only local-with-filesystem and trusted local SWF files may access local resources
    som_che
      I am trying to load a XML file in a Flex and BlazeDS based application.
      It gives me this error:
      SecurityError: Error #2148: SWF file http://localhost:8080/XYZ1/XYZ1I-debug/XYZ.swf cannot access local resource file:///C:\Documents and Settings\Adobe Flash Builder 4 Plug-in\AAA\src\assets\test\imagesOutput.xml. Only local-with-filesystem and trusted local SWF files may access local resources.
      I already tried the following options:
      1. adding the -use-network=false to compiler options
      2. Selected "Always Allow" in Global Privacy Settings panel
      3. using URLLoader instead of  <fx:XML id="xml" source ="<Local file system path>" />
      Please let me know if how can i get rid of this problem.
      Thanks in advance.
