1. Re: Indesign CS5 plugin not dectecting valid extension
Steven.. Jun 10, 2010 3:11 PM (in response to nope0000)On Windows new to CS5 you have to copy resources folder besides the plug-in to enable multi-threaded access to resource files
2. Re: Indesign CS5 plugin not dectecting valid extension
nope0000 Jun 10, 2010 3:29 PM (in response to Steven..)Could find the folder but not where to copy it to.
Also resource folder is created for sample project but not for my own (ported) project.
Where do i have to copy the resource folder and what do i have to change to get the resource folder created for my ported project?
3. Re: Indesign CS5 plugin not dectecting valid extension
copy into the same folder s plugin
Very hard to track.
Rather use dolly from CS5 sdk to create new plug-in with your info and add files
4. Re: Indesign CS5 plugin not dectecting valid extension
nope0000 Jun 10, 2010 10:03 PM (in response to Steven..)Thank you for your answer. I got it running.
I already tried to copy the resource folder of a sample project's plugin to the plugin folder after your first answer what didn't work because i had renamed the plugins name before. a mismatch between the plugins name and the resource folder name does result in the same error message like if the folder wasn't copyied at all.
To port a VS 2008 Project from CS4 to CS5 i had to change the following in the VS2008 project file to get the resource folder built:
Replace two entries from
#### CS4 SDK Project File: ####
<Tool
Name="VCPreLinkEventTool"
CommandLine="merge_res.cmd "$(IntDir)" Projectname"
/>#### CS4 SDK Project File: ####
with the according entry in
#### CS5 SDK Project File: ####
<Tool Name="VCPreLinkEventTool" CommandLine="merge_res.cmd "$(IntDir)" Projectname &del /f /s "$(TargetDir)($(TargetName) Resources)\"*.idrc & xcopy /E "$(IntDir)\"*.idrc "$(TargetDir)($(TargetName) Resources)\" /Y"/>
5. Re: Indesign CS5 plugin not dectecting valid extension
new_be Oct 27, 2010 5:13 AM (in response to nope0000)I followed the same below steps to plugin my Indesign plugin which was writt
en for cs4 to cs5.
I got the same error that Indesign cs5 doesn't recognize the xy.pln.
I tried changing the visual studio project file and rebuild my code in visual studio 2008.
I recive the following errors.
Performing Pre-Link Event...
1>Bad arguments to merge_res.cmd
1> Usage
1> 1)merge_res.cmd $(IntDir) ResourceFile
1> 2)merge_res.cmd $(IntDir) ResourceFile CoreResourceFile
1>Use 1) if the platform and core resourfile names are the same.
1> Use 2) if they are different.
1> Where ResourceFile is the filename without .res
1> CoreResourceFile is the filename without .fres
1> Example: 1) merge_res.cmd $(IntDir) TableModel
1> 2) merge_res.cmd $(IntDir) TableModel TableModelCore
1>merge_res.cmd done.
1>The system cannot find the file specified.
1>Invalid parameter - /E"..\objR\MediaBin\"*.idrc
1>Project : error PRJ0002 : Error result 4 returned from 'C:\WINDOWS\system32\cmd.exe'.
Please help me out what I am doing wrong.
Ram
6. Re: Indesign CS5 plugin not dectecting valid extension
new_be Oct 27, 2010 6:27 AM (in response to Steven..)I got the resource folder to be copied.
Even if I copied the resources folder, I am getting the same error that xy.pln is not a valid plugin and is not recognized by Indesign cs5.
Can you please guide me what wrong i have done?
I had written my plugin using visual studio 2005 for cs4.
For cs5, I recompiled the code with visual syudio 2008 and made necessary changes to get the resources folder.
7. Re: Indesign CS5 plugin not dectecting valid extension
Peter Schülke Oct 27, 2010 6:45 AM (in response to new_be)I just produced that very same error after moving the expanded folder from my zip file, which I generated from the resource folder. I opened the installed resource folder and noticed that it contains a second folder, which contains the resourefolders. As a Mac user I did not expect winzip to generate a base folder conatining the original contents at zip time. After moving the contained resource folder from the unzipped archiv into plugins instead of the unzipped base folder all worked well.
Could you've been trapped by this behaviour of winzip too?
8. Re: Indesign CS5 plugin not dectecting valid extension
new_be Oct 28, 2010 5:07 AM (in response to Peter Schülke)When I compiled my plugin code with visual studio 2008
, I got the resources folder copied to my InDesign installation directory
but while starting the application i still recieve the same error.
Am I missing anyotherthing?
9. Re: Indesign CS5 plugin not dectecting valid extension
new_be Nov 2, 2010 4:09 AM (in response to Peter Schülke)This is what below I get after all my source files are compiled.
I have made changes to the Pre-link event configuration.
1>merge_res.cmd - calling ConcatRes
1> 1 file(s) copied.
1>Error: not a res file
1>Usage: ConcatRes <main res file> <res file to concat>
After this I get some 13 resources folder generated. But still the plug-in doesn't load. I am working with windows, later I have to do with MAC.
Any guess what could have been wrong.
Please suggest me. Any help will be great.
10. Re: Indesign CS5 plugin not dectecting valid extension
nope0000 Nov 3, 2010 4:11 PM (in response to new_be)there is a post somewhere in this forum where someone told thad copying project folders and rewriting project files is very hard.
it worked for me and i didn't found it a hard or time consuming task, however, if you don't get it to work that way, you may wan't to take the official way to not loose time.
btw, i have no idea about the other way, i like clear text, what project files in fact are.....
