0 Replies Latest reply on Jun 10, 2010 6:55 PM by jmurphy67
    [svn:fx-trunk] 16531: player 10.1 is now the default player for trunk
    jmurphy67 Level 1
      Revision: 16531
      Revision: 16531
      Author:   jimurphy@adobe.com
      Date:     2010-06-10 18:55:05 -0700 (Thu, 10 Jun 2010)
      Log Message:
      -updated player names and paths
      -packaging will only pick up the target player
      QE notes: no
      Doc notes: no
      Bugs: https://bugs.adobe.com/jira/browse/SDK-26678
      Reviewer: lauren
      Tests run: checkintests
      Is noteworthy for integration:
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-26678
      Modified Paths:
          flex/sdk/trunk/build.properties
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/projects/airframework/build.xml
          flex/sdk/trunk/frameworks/projects/airspark/build.xml
          flex/sdk/trunk/frameworks/projects/automation/build.xml
          flex/sdk/trunk/frameworks/projects/automation_air/build.xml
          flex/sdk/trunk/frameworks/projects/automation_airspark/build.xml
          flex/sdk/trunk/frameworks/projects/automation_dmv/build.xml
          flex/sdk/trunk/frameworks/projects/automation_flashflexkit/build.xml
          flex/sdk/trunk/frameworks/projects/automation_spark/build.xml
          flex/sdk/trunk/frameworks/projects/datavisualization/build.xml
          flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
          flex/sdk/trunk/frameworks/projects/flex/build.xml
          flex/sdk/trunk/frameworks/projects/framework/build.xml
          flex/sdk/trunk/frameworks/projects/halo/build.xml
          flex/sdk/trunk/frameworks/projects/mx/build.xml
          flex/sdk/trunk/frameworks/projects/osmf/build.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/build.xml
          flex/sdk/trunk/frameworks/projects/rpc/build.xml
          flex/sdk/trunk/frameworks/projects/spark/build.xml
          flex/sdk/trunk/frameworks/projects/sparkskins/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/wireframe/build.xml
      Removed Paths:
          flex/sdk/trunk/frameworks/libs/player/10.0/
          flex/sdk/trunk/in/player/10/
