1 Reply Latest reply on Jun 10, 2010 10:36 PM by BhaskerChari
    A query related to ProgressBar and its placing inside Container
    kiran7881 Level 1
      Hi ,
      I tried an example with  Flex3 ProgressBar .I am posting the scenario in which it was correct in one case and wrong in another case .
      Please tell me what  is wrong here in the wrong case :
      The Program is related to :
      I have button on click of that i will be loading the Image . There is no Button and its event Listener Mentioned here .
      Correct Approach :
      This works fine as the Image and ProgressBar are in the same Container called HBox
      <mx:HBox>
      <mx:Image id="image" autoload="false"/>
      <mx:ProgressBar id="MYPB" source="{image}"/>
      </mx:HBox>
      Wrong Approach :
      The below isn't working as i placed ProgressBar outside the container called as HBox
      <mx:HBox>
      </mx:HBox>
      Please share your ideas as why this behaves this way .
        • 1. Re: A query related to ProgressBar and its placing inside Container
          BhaskerChari Level 4
          Hi Kiran.
          I don't think either of the approach is wrong , it no way effected by placing the ProgressBar inside a container or outside the container.
          Run the sample application below. It will load for both approaches.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
          <mx:Script>
                  <![CDATA[
                      public function loadImage1():void {
                        image1.load('assets/liazon_logo.png');
                      public function loadImage2():void {
                        image2.load('assets/liazon_logo.png');
              </mx:Script>
          <mx:HBox>
            <mx:Image id="image1" autoLoad="false"/>
          </mx:HBox>
          <mx:ProgressBar id="MYPB1" source="{image1}"/>
          <mx:Button label="Load Image1" click="loadImage1()"/>
          <mx:HBox>
            <mx:Image id="image2" autoLoad="false"/>
            <mx:ProgressBar id="MYPB2" source="{image2}"/>
          </mx:HBox>
          <mx:Button label="Load Image2" click="loadImage2()"/>
          </mx:Application>
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
