2 Replies Latest reply on Jun 11, 2010 7:01 AM by BhaskerChari
    AIR INSTALLER BUILDING IN FLEX BUIDLER
    savz Level 1
      How can i generate a air installer for a flex project build in flex builder?
        • 1. Re: AIR INSTALLER BUILDING IN FLEX BUIDLER
          Rdsingh Ldh
          Follow the steps below:
          1) Select your Project in FlexBuilder and ---then go to Project >> Export Release Build in FlexBuilder IDE You will see a window getting opened as shown below
          2) In the window leave all the options same and click next you will see the below window.
          3) In the window now click Create..button . You will get the below window. Fill the information in the TextBoxes given(Any dummy info).
          Give any name for the Save as option and save the certificate in some location by clicking the browse button and then click OK and then click Finish.
          That's it you are done...You can now see the installer being created in your application project folder as yourappname.air
          If this post answers your question or helps, please kindly mark it as such.
          • 2. Re: AIR INSTALLER BUILDING IN FLEX BUIDLER
            BhaskerChari Level 4
            Hi Rdsingh Ldh,
            Good work !! Keep it Up...
