1 Reply Latest reply on Jun 14, 2010 5:36 AM by BhaskerChari
    SWFLoader - Loading swf files that have sound
    jseekumar
      I am using Flex sdk 3.0. In an example I am trying out, I have a SWFLoader and 2 Buttons. When the first Button is clicked, I am loading the SWFLoader with a swf file (that has sound). When the second Button is clicked, I am loading the SWFLoader with a different swf file (that has sound too).
      The issue I am facing is - when the second swf file is playing, I am hearing sounds from both the swf files.
      I am just using the SWFLoader's load() method in each of the Button's click-event-handlers.
      Could anybody help me how I could solve this issue?
      Thank you.
        • 1. Re: SWFLoader - Loading swf files that have sound
          BhaskerChari Level 4
          Hi jseekumar,
          Try to make use of the SwfLoaders unload method.
          When you click second button try to unload the first SWF file by using the below line of code....
          swfLoader.unloadAndStop(true);
          After this try to assign the new SWF source as below:
          swfLoader.load("secondswf.swf");
          Try to set the autoload propert of the SWF to false.
          Hope this helps..
          If this post answers your question or helps, please kindly mark it as such.
          Bhasker Chari
