2 Replies Latest reply on Jun 12, 2010 2:10 AM by Poo_Del
    AppleScript--IDCS4--Label
    Poo_Del
      Dear All,
      Please see below code to create one text frame and label it.
      tell application "Adobe InDesign CS4"
              try
                         set myFont to font "Arial"
              end try
              set user interaction level of script preferences to never interact
              set myDocument to active document
              tell myDocument
                         set myString to "Ad Name:" & tab & "item 2 of argv" & return & "Advertiser:" & tab & "item 5 of argv" & return & "Run Date:" & tab & "item 6 of argv" & return & "Size:" & tab & "item 3 of argv X item 4 of argv" & return & "Color:" & tab & "item 7 of argv" & return & "Sales Rep:" & tab & "item 8 of argv" & return & "Status:" & tab & "item 9 of argv"
                         set myBounds to my myGetBounds(myDocument, page 1)
                         set myPage to page 1 of myDocument
                         tell myPage
                                   set myTextFrame to make text frame with properties {geometric bounds:my myGetBounds(myDocument, myPage), contents:myString}
                                   set label of myTextFrame to "myRemoveFrame"
                         end tell
                         set myStory to parent story of myTextFrame
                         tell text 1 of myStory
                                   try
                                             set applied font to myFont
                                   end try
                                   set point size to 6
                                   convert to table
                         end tell
              end tell
      end tell
      on myGetBounds(myDocument, myPage)
                         tell document preferences of myDocument
                                   set myPageWidth to page width
                                   set myPageHeight to page height
                         end tell
                         tell margin preferences of myPage
                                   if side of myPage is left hand then
                                             set myX2 to left
                                             set myX1 to right
                                   else
                                             set myX1 to left
                                             set myX2 to right
                                   end if
                                   set myY1 to top
                                   set myY2 to bottom
                         end tell
                         set myX2 to myPageWidth - myX2
                         set myY2 to myPageHeight - myY2
                         return {"-5pt", myX1, "-59pt", myX2}
              end tell
      end myGetBounds
      In Event log it is showing applied but when I am trying below code for deleting this frame it is not identifying this text frame.
              tell document 1
                         try
                                   set myPageItems to page item "myRemoveFrame" of page 1
                                   repeat with aFrame in myPageItems
                                             if class of aFrame is text frame then delete aFrame
                                   end repeat
                         end try
              end tell
      end tell
      Regards,
      Poo
        • 1. Re: AppleScript--IDCS4--Label
          Poo_Del Level 1
          Guys it was all are my fault.
          Below is the corrected code and working fine. Now I want to convert this below code for vbscript. I am not experienced in vbscripting part.
                  tell document 1
                             try
                                       end repeat
                             end try
                  end tell
          end tell
          Regards,
          Poo
          • 2. Re: AppleScript--IDCS4--Label
            Poo_Del Level 1
            Please help me by finishing up this my work any one can provide me javascript also for the above pice of code.
            Regards,
            Poo
