5 Replies Latest reply on Aug 4, 2017 9:28 AM by shawalaahmed
    Checking Punctuation
    Oviya... Level 1
      Hi friends
                     Can we check punctuation marks in every end of the line in Indesign document.
        • 1. Re: Checking Punctuation
          Peter Kahrel Adobe Community Professional & MVP
          Check in what way?
          - "Line" as in end of line or end of paragraph?
          - Check whether there is a punctuation mark or whether there isn't?
          - Check for which kind of punctuation?
          - Just one punctuation mark or more?
          - In which version of InDesign?
          - Which platform?
          - Which script language?
          There's a start!
          • 2. Re: Checking Punctuation
            Oviya... Level 1
                      1. Start & End of the Line in every paragraph. Not end of the paragraph.
                      2. All the punctuation marks we have to check, and it dont want to appear more than 2 times in end of the line in a paragraph.
                      3. If its appered more than 2 times in the paragraph ie start or end of the line we have to identify tat paragraph.
                      4. I need to find this Punctuation marks in Indesign file using InDesign Scripting [Indesign CS4]
            • 3. Re: Checking Punctuation
              Harbs. Level 6
              This will give you an array of the contents of each line. You can loop through that and figure out what you'd like...
              • 4. Re: Checking Punctuation
                SB Masthan Level 1
                Hi All,
                I am also expecting the answer for this discussion. How can we compare the punctuation elements with the content. I have tried with below command but couldn't get the result. If any solution to compare the content with puntuations globally, it will be really helpful for us.
                                if (ln[i].contents.substring(ln[i].contents.length - 1, ln[i].contents.length - 2) == "[[:punct:]]")
                • 5. Re: Checking Punctuation
                  Why not? Here I brought a useful punctuation checker. I hope this one will helpful for you.
