4 Replies Latest reply on Jun 12, 2010 9:10 AM by Davdi1982
    States, From Flash to Flex!
    Davdi1982
      Hi - I'm new of Flex.
      I have see that if i select Flex SDk 3.5 or ADOBE SDK (i want to build Extensions for Illustrator) than i can create State nested in other State.
      State 1
          State 1.1
          State 1.2
      State 2
          State 2.1
          State 2.2
              State 2.3
      Instead, If i select Flex 4 SDK i can't nested an State inside other State.
      Basically, i want to create an Application that can be in 3 State.
      Login
         - Success
         - Failed
      Admin
         - CreateUser
         - EditUser
         - ManageUser
      User
        - CreateProfile
        - EditProfile
        - GetProfile
      What is the best method in order to do That?
      In flash:
      3 MovieClip, every movie have 'n' frame ... or 1 MovieClip for every "SCREEN" and i create it dinamically with new .... and addChild.
      In Flash is Easy for me ... But in Flex? :-)
      da.
        • 1. Re: States, From Flash to Flex!
          David_F57 Level 5
          hi,
          What you do is create your application with the 3 states login, Admin, User,
          Theses state each include a form/page
          login.mxml
            has 2 states - Success, fail
          Admin.mxml
          has 3 states - create, edit , manage
          User.mxml
          has 3 states - create, edit, get
          If you want each of those states could be in their own mxml.
          http://gumbo.flashhub.net/wizard/  source included.
          This is a very basic 3 state application each state in its own mxml file. It Will give you an idea of states controling 'pages'.
          David.
          • 2. Re: States, From Flash to Flex!
            Davdi1982 Level 1
            Hi - Thanks you.
            I'm in LOGIN_PANEL and i want to get reference of a TEST_PANEL (created by me).
                     protected function button1_clickHandler(event:MouseEvent):void
                            // TODO Auto-generated method stub
                            var myB:Browserstyle_Navigation = this.parentDocument as Browserstyle_Navigation;
                            trace(myB.name+"_"); // trace - Browserstyle_Navigation0_
                            trace(myB.mytestPanel); trace - null
            In the Browserstyle_Navigation.MXML:
                <s:states>
                    <s:State name="LoginPanel"/>
                    <s:State name="EntryPanel"/>
                    <s:State name="ResultPanel"/>
                    <s:State name="TestPanel"/>
                </s:states>
                <ns1:test_pnl name="myTestPanel2" id="myTestPanel" includeIn="TestPanel" horizontalCenter="0" verticalCenter="0">
                </ns1:test_pnl>
            DA.
            • 3. Re: States, From Flash to Flex!
              David_F57 Level 5
              hi,
              With states they only get instantiated when they are displayed if you want to send something to a state or read a value in it you need to set its creationpolicy to all so that it is initialised at the beginning instead of when it is displayed.
              David.
              • 4. Re: States, From Flash to Flex!
                Davdi1982 Level 1
                With this example, i want show you that when i work with Illustrator SDK (inside Flash Builder) i can create state inside other state.
                Why i can't do it with a normal Flash Builder Project? :-)
                DA.
