2 Replies Latest reply on Jun 13, 2010 4:45 AM by anxious33
    How to specify that a field in a datagrid is an URL ?
    anxious33 Level 1
      Hello,
      in my datagrid i've a field which contains a single URL. How to make it clickable and open the url in the browser ?
        • 1. Re: How to specify that a field in a datagrid is an URL ?
          David_F57 Level 5
          hi,
          protected function dataGrid_itemClickHandler(event:ListEvent):void
          var str:String=dataGrid.columns[event.columnIndex].dataField;
          switch(str)
          case 'nom':
          getServeurByNameResult.token = serveurService.getServeurByName(event.itemRenderer.data.nom);
          break;
          case 'siteweb':
          navigateToURL( new URLRequest(event.itemRenderer.data.siteweb),'_blank');
          break;
          now you can update the second grid if you click on the nom cell and got to the url if you click on the siteweb cell.
          You no longer need a click on datagrid event use itemClick instead.
          <mx:DataGrid x="23" y="82" width="965" height="237" id="dataGrid"
          itemClick="dataGrid_itemClickHandler(event)"
          creationComplete="dataGrid_creationCompleteHandler(event)"
          dataProvider="{getAllServeurResult.lastResult}">
          David.
          • 2. Re: How to specify that a field in a datagrid is an URL ?
            anxious33 Level 1
            awesome, thanks for your reply
