1 Reply Latest reply on Jun 13, 2010 12:54 PM by Flex harUI
    Compile-time error: Unexpected multiname type: 16 ...
    sascha/hdrs
      I'm getting an oddball of a compile-time error which I cannot make head or tails of. Maybe somebody knows more about this? ...
      This is the full error I'm getting:
             D:\Work\Dev\Eclipse\com.hexagonstar.hexagon\swc\hexagonlib_flash.swc(com.hexagonstar.util :VectorUtil)
             Error: Type was not found or was not a compile-time constant: .
      I have a static util class named VectorUtil in a class library compiled as a SWC which i'm using in another project. A method I'm using from that class is the following one which generates a String-typed Vector from a provided Array ...
               * Creates a Vector of type String that is populated with strings from
               * the specified array.
               * @param array An array with string values.
               * @param sort true if the vector should be sorted.
               * @return A vector with strings.
              public static function createStringVector(array:Array,
                  sort:Boolean = false):Vector.<String>
                  var v:Vector.<String> = new Vector.<String>();
                  for each (var i:String in array)
                      v.push(i);
                  return sort ? v.sort(sortStrings) : v;
               * sortStrings
               * @private
              private static function sortStrings(x:String, y:String):Number
                  if (x < y) return -1;
                  else if (x > y) return 1;
                  else return 0;
      ... this seems to be all allright but  in the other project is a class which uses the createStringVector() method like this:
               * Parses a string made of IDs into a String Vector.
               * The IDs in the string must be separated by commata.
               * @private
               * @param string The string to parse ID values from.
               * @return A Vector with string values.
              protected static function parseIDString(string:String):Vector.<String>
                  if (string == null || string.length == 0) return null;
                  string = string.split(" ").join("");
                  return VectorUtil.createStringVector(string.split(","));
      ... The strange things is that if I compile not the swc but add the sources of my code lib to the compiler arguments it works! But if I specify the SWC to compile I get the above error.
