2 Replies Latest reply on Jul 14, 2010 7:03 AM by Anirudh Sasikumar
    Internal build error (while migrating from 3.5 to 4)
    kobster_
      Hi there,
      I'm migrating from 3.5 to 4, and have some issues with the (incremental) build process.
      Every time I try to compile the project (even after adding just a space) I get the internal build error.
      This error disappears upon a clean build (which is, expectedly, a lot slower).
      Another issue is the clean build time of the (almost) same project (flex 4 is at least two times slower than flex 3.5).
      Below attached the relevant entry in the log file.
      I'll appreciate any help,
      Kobi
      The log file:
      !ENTRY com.adobe.flexbuilder.project 4 43 2010-06-13 12:46:51.036
      !MESSAGE Uncaught exception in compiler
      !STACK 0
      java.lang.ArrayIndexOutOfBoundsException: 1129796362
      at flex2.compiler.PersistenceStore.readCompilationUnit(PersistenceStore.java:1568)
      at flex2.compiler.PersistenceStore.readCompilationUnits(PersistenceStore.java:1541)
      at flex2.compiler.PersistenceStore.read(PersistenceStore.java:958)
      at flex2.compiler.CompilerAPI.loadCompilationUnits(CompilerAPI.java:4844)
      at flex2.compiler.CompilerAPI.loadCompilationUnits(CompilerAPI.java:4823)
      at flex2.tools.oem.Application.loadCompilationUnits(Application.java:706)
      at flex2.tools.oem.Application.recompile(Application.java:1071)
      at flex2.tools.oem.Application.compile(Application.java:819)
      at flex2.tools.flexbuilder.BuilderApplication.compile(BuilderApplication.java:344)
      at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder$MyBuilder.mybuild(A SApplicationBuilder.java:276)
      at com.adobe.flexbuilder.multisdk.compiler.internal.ModuleBuilder.build(ModuleBuilder.java:1 37)
      at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.build(ASBuilder.java:190)
      at com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuilder.build(ASItemBuilder.java:7 4)
      at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.buildItem(FlexProjectB uilder.java:480)
      at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.buildModules(FlexProje ctBuilder.java:421)
      at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(FlexProjectBuild er.java:319)
      at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(FlexIncremen talBuilder.java:157)
      at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:627)
      at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:170)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
      at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:253)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:256)
      at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:218)
      at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:360)
      at org.eclipse.core.internal.resources.Project$1.run(Project.java:523)
      at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1800)
      at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1782)
      at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:502)
      at org.eclipse.core.internal.resources.Project.build(Project.java:94)
      at org.eclipse.ui.actions.BuildAction.invokeOperation(BuildAction.java:221)
      at org.eclipse.ui.actions.WorkspaceAction.execute(WorkspaceAction.java:162)
      at org.eclipse.ui.actions.WorkspaceAction$2.runInWorkspace(WorkspaceAction.java:483)
      at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38 )
      at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
        • 1. Re: Internal build error (while migrating from 3.5 to 4)
          donwebtech
          Same here:
          at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder.build(ASApplication Builder.java:127)
          at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(FlexProjectBuild er.java:306)
          at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:309)
          at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:341)
          at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:140)
          at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:238)
          • 2. Re: Internal build error (while migrating from 3.5 to 4)
            Anirudh Sasikumar Adobe Employee
            This is a compiler bug being tracked as: https://bugs.adobe.com/jira/browse/SDK-26799
